6700xt General Discussion
I getting 47MH on nbminer and 93W, 0 invalid or reject shares
Thanks for sharing your OC, works very well. my gpus are running at 46.4 mh/s ~ 46.5 mh/s with a power draw of 85w ~ 90w.
I am using team red miner if anyone is interested.
Hi Everyone,
I’m new to mining and stuck with a problem can’t seem to get out of. Im trying to build a rig with 8 Sapphire 6700XT cards running on hive OS. The worker is unable install any miner, I tried phoenix, teamred, nbminer, etc.
It keeps saying ā€œsegmentation faultā€. Have tried flashing the USB multiple times. Have attached the log screenshot for reference. Any help will be appreciated.
Maybe it’s because you are using version 0.6-208. You could try to update to 0.6-209.
it’s most likely because you are using a usd stick instead of a ssd. If you don’t have an ssd the try a hdd, usd sticks are not reliable.
Hi somebody help?
6700xt dont work
my image is the last
0.6-209@210831
tks
miner ?
what is your voltage configuration ?
Hi try.
TMR,NbMIner, LolMIner…
voltage hi try stock and oc
i try to a direfent OS
The problem is, the 6700Xt is " Unknown " you se in print?
tks
Can someone help me with this madness…? :smiley: I tried a lot of OC, but with every OC i’m getting 43 @ 162W. That’s terrible…
Tried Team Red Miner and nbminer, but still no luck.
Drivers version 20.40 (5.11.0701)
try this setup,let me know how it works
Same :frowning:
try my setting i getting 47mh on nbminer
CORE 1285
VDD 650
VDDCI 730
MVDD 1270
MEM 1075
Still nothing :frowning:
try an older stable version (not downgrade), 203 or 205 Hive OS Images Historical Releases
Hello! Maybe problem in riser? I have MSI MECH too, this is what I’ve got. GMiner v.2.66
pool ethermine
miner nbminer 39.2,
Stale %0 or %1
This happens when your Kernel isn’t the latest version.
Can you please take a screenshot of your kernel and OS version
I just find out my issue… For some weird reasons, OC settings are not applied even when i receiving green success message :smiley: great UX, hiveOS.
NVM, now, i’m trying to figure out why only thing that changing is FAN…
Guys, i just figure it out that OC bug…
After replacing new hiveOS image everything works correctly. This command saved me, lol:
exec hive-replace -y --stable
So now results are pretty cool
