Ok, how much do you have consumption of electricity with this OC? I musted set power limit to 120W because without any OC setting I have temepratures about 80C and fans go on 100%.
46.5mh@76w
Fan sits @28%
Temps core 43° mem 54°
I have autofan on for all my cards set at 78° Max For the mem
You have to upgrade the OS!
Driver version is 5.9 you need 5.11 then the power consumption goes down.
Command: hive-replace -y âstable
Then update
Does anybody can help me with my second 6700 xt?
https://forum.hiveos.farm/t/rig-crashes-as-soon-mem-oc-changes/47682?u=maahhnian
hi, I have rx570 8gb and rx 6700xt video cards. But I canât run two cards at the same time in hiveos. If I put 6700 xt first, rx 570 cards donât work. First of all, if I install the rx 6700 ones, this time the rx 570s do not work. I think itâs a driver conflict. How can I solve this problem?
What are you currently OC setting? Have you updated hiveOS and driver to 5.11? I used your settings and everything was cool!
Sapphire are very hot atm
Looks like your motherboard is so old. Did you check the cards if they work in Windows? May you need to try to update the motherboards BIOS or to change something in the settings.
My rig works fine with a mix of RX 470 RX 5700 and RX 6700.
hallo, i have the âunknows gpuâ , i have power color red devil 6700xt , and the latest OS, i tried several phoenix miner anr teamredminer but nothing , the gpu dont start mining and the data is missing ,can someone help ?
finally installing Beta 0.6-208@210818 solved the issueâŚ
You need to update your dirvers/oc
Use Command: hive-replace -y âstable
hallo, some of you have settings for 6700xt hellhound power color ? i cannot rind a stable setupâŚ
hello guys, iâm going to buy some amd rx 6700 xt but I donât know which model is the best. Which one should I get the PowerColor Red Devil AMD Radeon RX 6700 XT 12GB GDDR6 or the Sapphire NITRO+ AMD Radeon RX 6700 XT GAMING OC 12GB GDDR6 (i get them for the same price but i need to choose between)
Thanks!
