I am using 0.6-205@210715 with amd drivers 20.40 (5.11.0701)
I only changed core, memory controller and memory voltage with the setting of the image, nothing else. And the miner is nbminer.
I havenât verified the consumption by the wall (I donât have a smart plug or something like that), so I am not sure if that is exactly what my card is using. As soon as I get a smart plug I will update here.
Aah im using Gminer and got it now on 104 w, changed the SoC VDDmax and that would decreased the wattage and increased hashrate.
Ive just seen this video on YouTube, Can this be right? running two miners at once giving about 67mhs???
This must be unstable.
Hi there:
Just wondering what power supply are you using? I am running 5 6700xt, it gives about 875w at the wall. with my 1000w power supply. I donât think I can put in the 6th card in my rig. so 100w ish per card + 36w for a riser card would put me over 1000w limit.
Let me know! Thanks!
I use two blocks, the first is cooler Master 1000W Gold and the second is Aero cool 850W gold and I connect the two with a double PS connector. for you it is necessary to be careful because for a PS 1000w gold it is not necessary to exceed the 800w (ps certify 80Gold: the guaranteed power is 1000w * 80% = 800w).
so I advise you to add another PS.
5 6700xt using 875 too much. mine 1 card only 96-108w.
with 875 w it is almost 90% of the power supply, it is a lot, to start with 5 6700xt your consumption would have to be 725 w and with hiveos 0.6-205@210715 the consumption would have to be approximately 660 w, in my case I am using two power supply 650w for 6 6700xt
67mhs I do not think they are real, maybe when two miners act, they are more wrong, you have to see how the pool reports them
Hi guys, can you share with me the best overclockg setting please? Im new with HiveOS. I have 8 pcs of XFX Speedster QICK 319 Radeon RX 6700 XT 12 MB GDDR6 in mining box powered by 2500W PSU and 4 pcs strong fans for cooling. My default mining speed is 34,70 Mhz but I would like more but safety for GPU.
Iâm using this Flight sheet -
better to use Teamredminer (46,5 mhs) or Nbminer (47 mhs), hiveos 0.6-205@210715, core clock 1180, core voltage 700, Memory clock 1075 ,
I changed setting because when I put 8 gpus in box the temperature was about 70-80 C and FAN 100%. It so hot. I read some tip on this formu how to clock and it see fine. Only one card is lazy.
Wow thanks for this! I applied it to my XFX cards and it is telling me 92w for 46.9Mh/s. Massive improvement!
what miner are you using ?
DPM used only for Polaris and prior GPUs
NB miner
Sometimes - 2-3x per day my one of 8 GPU is lost in HIVE OS or the power goes down and my watch dog must make restart do go full Hashrate. Iâm thinking about stability of minning. Is it normal so I must restart rig for example 4x per day?
My OC is: CORE: 1300 600/675/1225 MEM: 1075 PL: 12thanks guys
