Thanks! Changing the miner to NBMiner raised my Hash to your numbers. Also it does great job dual mining ETH / ZIL.
Good afternoon, these are the settings I’m currently using, there are two RX 6700XT, one Powercolor and the other XFX, I was using another OC setting, but it started to generate some invalid shares, with the current settings, temperatures are much more low, hope it helps.
OBS: the mining software is TeamRedMiner, maybe using phoenix if you get a little more hashrate
[image]
46,9 for me but thats good enough
Could be a cabling issue but id start by using your fan speed to 70 and see if you can lower your memory temps.
Did you guys change the kernel version? I am getting around 300w less power consumption (on the wall).
Core: 1150
VDD: 680
VDDCI: 700
MEM: 1074
96W
Can u post your OC ?
I didnt bios mode it… so u dont need the vbios file… Just change the OC for what i’ve post
mind if u share more detals ? i tryed that but my power still same at 119-123w
do you have latest kernel version? 5.4.0-hiveos #132 A20.40 (5.11.0701)
Check if you have teamredminer 0.8.3
You have the wrong stable version. This one doesnt support 6700xt. Try with at least: 0.6-203@210419
Or change with NEW 0.6-205 2021-07-15 stable, which is even better for 6000 series.
I am on the latest release and was able to get the cards to 46.3 - 46.5 MH on Teamred. The power is at 119w anyway to reduce that and maybe get more MH out of it? I was getting more out of those cards on windows and was using Phoenix miner.
FYI- I have the powercolour 6700 xt not sure if this makes a difference.
i am mining with RX 6700 xt Power Color Red Devil in hiveos , team red miner.
46.5 mh with 100w.
i had 125w with original bios, but i put a bios from an Asus model to reduce power consumption.
I would love to do that. But so far I found the TeamRed miner to be the best for my rig in terms of stability. My rid has 2x 6700xt, 3x 580 RX, 2x Vega 64
