much better with these settings!! But still some invalids (6 in 3 hours)
Thanks!
No problem. Maybe drop to 1170 and that might be enough to keep her purring
Or raise a bit the voltage to sustain the higher core clock
Try lowering Memclock by increments of 5 until you get less invalid shares. For Polaris, you should be getting at most 1 invalid share in a week.
I need some help getting my card up to 32. I was running a different Os Before and was at 32 but now on hive my card is only 21 at best. I tried messing with settings what am I missing? any help appreciated…
You should try these settings:
Core Clock: 1800 ~ 1200
Core State: 1
Core Voltage: 800 ~ 850
Memory Clock: 2100 ~ 2150
Tweak (advanced config): amdmemtweak --REF 30
Hello to all
I am looking for the BIOS of this graphic model
Radeon RX 580 8192 MB · XFX
SK Hynix H5GC8H24AJR · 113-58085HAD0-M80
I used polaris bios editor but it gives me an error message
My country is due to Hess sanctions and I can not use polaris bios editor.
And I can not install the driver on my graphics.
Please, if anyone has graphics similar to mine, send a BIOS version to my Gmail
Thank
[email protected]
https://drive.google.com/file/d/1hlLbJv7Kuq4nX-42Elb_YDeefEZR-cEg/view?usp=sharing
here is my pcl 570 8g ss vram can someone help me to mod this bios thanks
Samsung K4G80325FB 113-D0003400_100
Hi There
I used your config on my RX 580 and it went up to 34.xx MH . However suddenly all other cards started to produce invalid shares .
my Question is what value do you enter in MDPM field ?
your answer is much appreciated .
Mdpm and dpm states are not used for rx580 cards.
Hello
I am new to mining.
Reading this topic helped me set my gpu to get good performance.
I there any way to reduce from 98w i’m getting?
Thank you
Have you turned on the button “agressive undervolting”? If no, that will make a huge difference.
If yes, then i’m sorry. There’s no way to reduce. While ago, I owned a RX590 Powercolor Red Dragon and that was exactly the wattage it produced. Then i sold it!
Memory controller voltage 800
Hi everyone!
Have some issue with my 590 MSI Armor card.
I hope someone have here experience, how can i do a bios mod on that card.
I can read it, but i can’t change the timings.
Any idea? I think, this card have another 2-3 Mhs for me.!(upload://7NSQSLS47f5Mthl568vDiwnEUhe.jpeg)
