Vega 56 and Vega 64 guide
@Matti
I have a problem with my Gigabyte 64 OC. I even wrote about it in this post
Could you share a link to bios which works best for you?
Thanks in advance.
Hi
i did flash this bios to my Gigabyte vega 64 gaming oc and i did use HiveOs and Force flashing to flash the bios
i have not test any other bios that is the only one
i get 46.7 mh/sec ETH mining with this setting
the highest on ETH mining i have got is 47.3 mh/sec but very unstable crash after about 20 sec
Thanks man. Works much better.
I mean it is not full speed (about 170 MH on ERG) but it is way better than before with 64bios. I’ll do some tests.
i get 180.5 MH on ERG
i use this setting
My card crashes with clock set to 1300, even I set core voltage to 920. Now I’m working on core 1200 and I try to go up each day if previous setting works stable.
This is very strange card. My other Gigabyte 64 OC gets 182 without probem.
Yes you are right Gigabyte vega 64 gaming oc is not so good card very sensitive card crashes very easy
Guys
I have another problem. Just bought Sapphire RX Vega 56 Triple DP OC.
I have two rigs able to power up this kind of card. On both, it is not recognized. I mean fans start spinning but the card is not on the list and it is also not shown on the console while booting up.
Meanwhile, on other computers with windows, it works as a single card. Strange is in it?
I sympathize with your problem, but unfortunately, except for a reboot, nothing will help. At least from my experience. If you find a succeed way and сould you write please.
anyone mining ergo with sapphire pulse samsung 56?
my gpu likes to drop dead few times a day. voltage 880, core 1350 memory 960.
amdmemtweak --RC 37 --RP 12 --WR 13 --CWL 8 --FAW 12 --RAS 22 --REF 65535 --RFC 239 --RTP 6 --RRDL 5 --RRDS 3 --WTRL 9 --WTRS 4 --RCDRD 13 --RCDWR 13
Hello all, I’ve been working on trying to tweak my cards a little better.
I’ve managed to get 52.62mh on my MSI Vega 56 Airboost.
I can get it over 53 if I raise mem to 980 but I get about 10 invalids a day.
Currently I’m getting 3 invalids a day.
Any suggestions? maybe something to change in the straps to see if can get rid of the invalids and maybe go a little higher on mem.
try Vega Ergo thread :+1:
https://forum.hiveos.farm/t/mining-ergo-with-vega-56-64/
I have 2 Hynix Vega 56’s churning nicely at 180mh/s and one flashed 64 at 200 mh/s using above straps.
I have a huge problem with my fourth card. It’s a 56 flashed to 64 by previous owner and can’t find a way to flash it back. When I have running with above straps for Hynix, I get the the 180 mph/s but with 33% hardware errors. No matter what I’ve changed it will also show up dead every 40 minutes or so on average.
Any advice would be greatly appreciated.
whats your settings for the hynix 56? I can’t get mine above 160MH/s without crazy power consumption
I have a Gigabyte Vega 64, I’m having hard troubles overclocking it…
So then I’ll like firstly flash it to a Vega 56, but cannot find the correct ROM, here is the error:
How can I choose the correct ROM?
did you flip the “force flash” switch on bios tab ?
Correct rom is usually your gpu´s manufacurer´s vega version 56 bios
I did not use “force flash”, should I?
If u have right ROM yes, it’s normal that flash is made with “force flash” enabled
OK. Thanks! I did it successfully
Any suggestions on getting the watts a little lower on my MSI Vega 56 Airboost?
I’m happy with the hashrate but I also get a about 2-3 invalids a day.
Thanks!
1075/850/960
I’m trying to get the best of my Vega 64 (now 56), but I get a lot of invalid shares and low hashrate…
any suggestion?
Current settings:
amdmemtweak --CL 20 --RC 36 --RP 12 --WR 13 --CWL 8 --FAW 12 --RAS 22 --REF 65000 --RFC 249 --RTP 5 --RRDL 5 --RRDS 3 --WTRL 9 --WTRS 4 --RCDRD 12 --RCDWR 12
I’ll like to remove the “5” in DPM, but cannot on the card settings neither in ALL card settings…
Thanks!!
