Hmm so it would be way more profitable to mine autolykos on this card right now? I’m gonna try it, thx!
moi. have flashed that 64 to 56 ?
Hi i have not
i think one here on the forum did do it that have the same card as i do
i have to test hiveos again it was maybe 1 year ago i did test it
Hi yes i have to test hiveos again it was about 1 year ago i did use hiveos and if i remember right i did have the same speed about 41mh / Sec
i have two Radeon™ RX VEGA 64 GAMING OC 8G and the speed is the same on does but im going to test hiveos again
Please also note that you’ll get better overall results when you flash those 64’s to 56 vbios.
There’s plenty to read about that in this topic.
almost twice as profitable as eth
no. always 56
when was that and for how long?
eight hours max
okay…interesting, maybe we should move conversation to vega/erg thread so we dont go to much OT
Hi how did you flash i did try today to flash one of my gigabyte 64 gaming oc but no go i did try amdvbflash 3.04+ and i did try with -fa and -fp to force it but no i did get all the time SSID mismatch
when i do the amdvbflash.exe -i i get nothing on the Bios p/n
If you using hiveos forum, use hiveos to flash ffs, not windows. Just click flash and check force flash. Goes smooth like butter
Hi ok i use Hiveos to maybe i try to flash on it then
hmm is it ok to flash a card if i use risers pci-e 1x ?
i have to first see what forum user Noach say because if i understund he have the same card he did write this in one forum post
Noach
Hey man. I just tried some things and learned that non reference vega 64 cards can’t be flashed with their 56 counterparts. They can, but rarelly works.
For example: I was trying to flash gygabite gaming oc vega 56’s bios on a vega 64 gygabite gaming oc. It bricked. And them gygabite’s vegas sucks btw.
Reference card bios works better. Try same brand reference.
In your case i’d try a sapphire reference 56 bios instead of a 56 nitro+ bios. If your card is bricked try to reflash it as i said. If nothing works reflash your backup 64 bios.(You did backup right?). Good luck.
This is my setup for Vega 56
amdmemtweak --CL 18 --RC 34 --RP 13 --WR 11 --CWL 7 --FAW 12 --RAS 23 --REF 17000 --RFC 148 --RTP 6 --RRDL 4 --RRDS 3 --WTRL 4 --WTRS 4 --RCDRD 15 --RCDWR 11
yes
ok thanks
Did vega 64 came with hynix memory? Trying to buy some Vegas but sellers never know what memory card they selling is using.
I see you have good result, and lot of experience.
I am a beginner, just started mining ± 3 weeks ago.
Still learning and experimenting.
i hown 3 rtx5700xt and one Vega 64 wc.
here my vega 64 RADEON RX VEGA 64 WAVE 8G
Flashed with this bios MSI RX Vega 56 8 GB BIOS (Air Boost)
I am using last hiveos beta, teamred miner 0.8.4 with option --eth_config=B ,
and with autofan Target Core TEMP 50°, and Target MEM TEMP 60°.
The best i can achieve for the moment is 54.86MH@124W.
The card is actually not in the rig but in a computer, the temp are very low 45°core mem 62° (fan +32%) @Room temp 26,6°
As everybody im am searching the highest ashrate for the lowest power concomption
For the moment i don’t understand which value affect the power and which one affect the ashrate.
The electricity rate is expensive in my country 0,20euro/Kwh ± 0,23$.
here what i have try:
amdmemtweak --CL 20 --RC 38 --RP 12 --WR 13 --CWL 8 --FAW 12 --RAS 26 --REF 24000 --RFC 239 --RTP 6 --RRDL 5 --RRDS 3 --WTRL 9 --WTRS 4 --RCDRD 12 --RCDWR 12
1097 / 810 / 1028
54.85 125w
amdmemtweak --CL 20 --RC 37 --RP 11 --WR 14 --CWL 8 --FAW 12 --RAS 20 --REF 65535 --RFC 248 --RTP 5 --RRDL 6 --RRDS 3 --WTRL 9 --WTRS 4 --RCDRD 13 --RCDWR 12
1080 / 800/ 1025
55.67 124w invalid share
amdmemtweak --CL 20 --RC 37 --RP 11 --WR 13 --CWL 8 --FAW 12 --RAS 22 --REF 65535 --RFC 239 --RTP 6 --RRDL 5 --RRDS 3 --WTRL 9 --WTRS 4 --RCDRD 12 --RCDWR 12
1080 / 800 / 1045
56.04 125w invalid share
amdmemtweak --RC 37 --RP 11 --WR 13 --CWL 8 --FAW 12 --RAS 22 --REF 65535 --RFC 239 --RTP 6 --RRDL 5 --RRDS 3 --WTRL 9 --WTRS 4 --RCDRD 12 --RCDWR 12
1130 / 830 / 1045
56.06 127W invalid share
1045 / 825/ 1130
8.778 56W
could you help?
its so hard to say anything solid, it just goes wrong.have u flashed that 64 with 56 corresponding bios?
My only 64 is flashed as 56 and it for me it brings wattage down on that gpu but the consumption is higher, i dont know is only cause 64 reguires a bit higher mem than 56, or is this my power color 64 “what ever dragon” just so power hungry that for stability it needs more juice, and performance is not on the same level with sapphire 56´s.
So u newer know.
Pay attention to more detail data like Soc values and fine tuning core/mem/vdd, and the relationship to minimum vdd so that u dont run your gpus too hard without any benefit, only power lost.
U can manually allso specify gpu --eth_mode intencity lower to some gpu that consumes lot or is running hot etc…
Here is my Miner screen, just adjusted something a bit for changing ambient here,
My straps for
all vega 56 with samsung,
all Hynix 56
amdmemtweak --RC 36 --RP 11 --WR 14 --CWL 8 --FAW 12 --RAS 20 --REF 65535 --RFC 248 --RTP 5 --RRDL 6 --RRDS 3 --WTRL 9 --WTRS 4 --RCDRD 12 --RCDWR 12
Power color vega 64 flashed to 56
amdmemtweak --RC 37 --RP 12 --WR 13 --CWL 8 --FAW 12 --RAS 22 --REF 65535 --RFC 248 --RTP 6 --RRDL 5 --RRDS 3 --WTRL 9 --WTRS 4 --RCDRD 12 --RCDWR 12
