Aawww
you are welcome
Hi i was also trying to get in TON mining but i have amd rx 6800 and best miner is lolminer but in hiveos when im trying to use lolminer mining ton it just dont start mining and says 0 hashrates any sugesions ?!
Can’t I check the walker I’m using?
Try to use all pool URLs. There can be DNS problem!
I’m using these
Server URLs
server1.whalestonpool.com
pool.services.tonwhales.com
Thanks again
Hi
I don’t think so… then we all would have the problem… imho he didn’t registered his wallet address at the Telegram bot
I’ve the same problem. Lol has restarted from time to time without any error in the log.
Here are last lines before restart
Ton job with difficulty 274.88G and giver Ef_NSzfDJI1A3rOM0GQm7xsoUXHTgmdhN5-OrGD8uwL2JHBa received.
Ton job with difficulty 274.88G and giver Ef8gf1PQy4u2kURl-Gz4LbS29eaN4sVdrVQkPO-JL80VhFww received.
Average speed (10s): 3165.86MH/s | 2334.97MH/s | 2263.25MH/s | 2327.00MH/s | 2295.12MH/s Total: 12386.20 MH/s
GPU 4: Found a share of difficulty 4578.87G
GPU 4: Share accepted (21 ms)
Ton job with difficulty 274.88G and giver Ef9iWhwk9GwAXjtwKG-vN7rmXT3hLIT23RBY6KhVaynRrDkx received.
Ton job with difficulty 274.88G and giver Ef8kO6K6Qh6YM4ddjRYYlvVAK7IgyW8Zet-4ZvNrVsmQ4PgP received.
Ton job with difficulty 274.88G and giver Ef8SYc83pm5JkGt0p3TQRkuiM58O9Cr3waUtR9OoFq716uj0 received.
After that there is a new log with new lolminer process.
Ahaa in dmesg is the error
[15798.285389] perf: interrupt took too long (2503 > 2500), lowering kernel.perf_event_max_sample_rate to 79750
[22471.840330] perf: interrupt took too long (3129 > 3128), lowering kernel.perf_event_max_sample_rate to 63750
[35217.145006] perf: interrupt took too long (3915 > 3911), lowering kernel.perf_event_max_sample_rate to 51000
[45257.744891] lolMiner[3641]: segfault at 10 ip 00007f8485f33317 sp 00007f84427f7308 error 6 in libc-2.27.so[7f8485e78000+1e7000]
[45257.744902] Code: 00 00 00 48 39 d1 0f 82 97 75 07 00 0f 1f 80 00 00 00 00 48 89 f8 48 83 fa 10 72 3e 48 83 fa 20 77 7e 0f 10 06 0f 10 4c 16 f0 <0f> 11 07 0f 11 4c 17 f0 c3 48 3b 15 31 54 33 00 0f 83 e2 00 00 00
Is this for lolminer developers?
Try with lower OC settings. It seems that lolMiner can’t use the calculations and therefore has to lower kernel power…
Not better sell TON coin for USDT and buy RVN and transfer it to main exchange ? Fee is like nothing xD
I am getting the same problem,
I am running 3 3080 Lhr
I am trying to lower OC to see if I get it stable
Next time I will try so and report.
oh yeah i have done all the thing that needed im fine mining on lolminer on windows but it just dont wanna work on hivos! do U have any AMD cards to test lilminer?!
I have AMD 6800, 6800XT and 6900Xt running on hiveOS right now Using Team Red miner
They are all kind of running different and some I have to lower power to keep heat down. I am not sure the best settings with AMD, I matched some youtube videos but got different results. All are AMD reference cards.
Sorry, no AMD cards here so far…
but other users don’t seem to have problems like you, look here. Therefore I think it’s no problem with lolMiner.
Edit: what are the version numbers of your HiveOS, AMD- driver and lolMiner?
evrything is updated to las version
U see i have 6800 and im getting 3.7G hashrate in windows but in hivos i can only use gminer that give me only 2.8g hasrate that is why im trying to use lilminer to mine ton :))
GMiner is able to mine sha256-ton?
Weird… did you follow the instructions written here? Otherwise you may ask the user @hotness how it works?! Sorry for not being able to help you, guy! I don’t mine directly in Windooze
Edit: what are your MSI Afterburner OCs for the RX6800 @ 3.7 GH/s? I just saw that @hotness even gets 2.8 GH/s with lolMiner…
Nice thread… I find it quite illustrative! kudos!
I will give it a try, as soon as I finish my weekly pool fro ETH.
Thanks!
