Awesome. I’ll try those. Thanks.
Do you mate a bios mod?
ref 30 usually, sometimes 50…but that dont make any big difference…some 580´s dont like even ref 30…just spitting invalids
here i tried to switch the miner but it gets even worse rebooting after 5 hours.
what is your whole setup with all oc 's? 580"s should be solid for longer ops…
switched back to teamredminer @Smining570
It used to works with ref 30 now i am testing ref 20.
But i never get past one day without the 580 rebooting the rig.
I am using the 009s riser an msi gaming plus max x470 , athlon 3000g paired with 16gb of ram and a xfx 750w power supply.
are u sure its 580 that causes reboot, if one of others “dies” it may be that the error is gpu0 dead when it reboits. have u ran 580 only for longer period? your values are fine, might as well drop vdd to 840 if Core 1150,im running 580’s now Mem 2060 vdd 840 core 1190 ref 30. these gives some invalids, usually on same gpu, xfx 590…but safe are for me 2140/840/1170 ref 30. these runs without any issues for days… usually i rise them ro higher values at some point then to the ones i mentioned earlier…
. and back again to stable when there is enough invalids. really hard to say what can cause Re oot after several hours… psu? Let us know how it goes with ref 20.hope it helps or u find another solution.
i’ll keep you updated, the other two are in the t-rex miner, the error that i am getting is in the team red miner , could be the nvdia cards ?
Yesterday i tried in the phoenixminer and i saw when it happens suddenly the hashrate from the 580 goes to 0 and the other two keeps hashing until the phoenixminer reboots cause rx was reporting as 0mh/s.
I tried 2140/840/1170 ref 30 reboots after 5 hours +/- the only one that i didnt tried yet was Mem 2060 vdd 840 core 1190 ref 30.
If it reboots i’ll try those , if doesnt work too i will try to run the 580 alone.
yes, i belive your issue is with nvidia, team red for amd is solid, do try 580 solo or only nvidias…im quesing if u go with nvidia u will have same reboot later,but will see
Buenos días, tengo este problema , como podría solucionarlos, muchas gracias de antemano.
no se si cambiar de team read miner por lolminer o tocar configuraciones de OCI have 9 cards running but once I add my 10th, no matter the slot it will run for up to 6 minutes and say that GPU is detected dead and restart the rig.
Is this similar to what you were having an issue with?
si es muy similar a lo que me esta sucediendo, ahora de momento he cambiado la configuracion y no esta dándome problemas
have u tried to increace vdd on that one that allways dies…?
I had the same problem here, I solved it by raising the core voltage of my gpu (Radeon 6700 XT). This problems seems to happen when u have to low core voltage. U should raise it 25 by 25 till u can find a number witch u get the rig stable.
le subi el vdd a 980 y me ha dado fallo al dia y medio mas o menos, debería de ir subiéndole mas?
Usually this is an issue with cards that may have poor cooling or something related to OC changes. But that is absolutely no reason to be concerned. TeamRedMiner works a bit differently. It catches minor overvoltages on the core or memory and turns off the digging, then reboots and the whole rig runs smoothly for several weeks. Nothing to worry about!
Of course, if the card is damaged, it’s a different matter.
