im have been on latest TRM for while now. I belive that i āsolvedā dead gpu issue by backing up ocĀ“s . I have now on 580Ā“s vdd at 846 mem 2140 and core 1170. It dosnĀ“t look like there is much difference in hash if mem is higherā¦for stable setup i assume its average mem 2140/core1150/vdd84-850/dpm&mdpm1/ref30-50.
The difference in total hash is so small that stability outweight the high hash and constant issues. I have been running high/med/low ocĀ“c on most of 5xx cards and defo have came to conclusion that its more profitable to run stable, not too high oc, that results more accepted shares, your 24hrs average stays high, no stale shares. These are just my observations and do not apply to all rigs and cards, there is other factors hat affects how certain gpus are workingā¦like what oyher gpus u have on the rigā¦like more powerfull amd/mixed rig, changing one gpu oc allways affects to others or some other card on the setupā¦then we can dive even deeper, how is power distripution, the psu power, risers-are they same gen,there is conflicts between lets say 006 vers 009 risers etc etc
anyway, hope u get your rig sorted out, if nothing else dont helpā¦reflash hive-delete your worker and start from clean slate, i have done that few times and everything have worked smoother after. good luck
