maybe someone has a hint for me.
(I do not want to reinvent the wheel)
What are the possibilities to influence the power consumption of the worker externally?
I want to use only solar power for mining. Grid power is much too expensive here in Germany.
I already have the power values of the solar system, the house battery and the consumers centrally under FHEM.
It is missing actually only possibility to control the Worker on some parameters. Start-Stop Mining ,Stutdown worker.
(you can switch on the thing via wake on lan)
The logic is very simple:.
Solar power > X
or
Battery < Y
DO
Shutdown
and the whole thing the other way around for WoL
do you have to enable SSH on the Workler only ?
and then :
ssh [email protected] ‘shutdown’
about SSH I found this:
the question is of course, could it be easier?
