I’ve tried reinstalling the OS, but I still can’t run the Selfupgrade command.
Are you using hive-replace?
I use hive os flasher.
try hive-replace -s in the shell, it sounds like your image youre flashing may be corrupt
It take over 14 hours for download, How to make it faster?
not help.
system is not corrupt.
thats after hive-replace completed? what OS version are you on now?
yes just finish with command hive-replace -s
and test to run command selfupgrade
Same situation here. I’ve just updated to the latest version using hive-replace -l selecting the latest version, and after the reboot selfupgrade command was missing. I’m at the same kernel and os version of the others.
Exactly same situation here, hope someone can help
Go here and remove/revoke any unfamiliar sessions/tokens
https://id.hiveon.com/auth/realms/id/account/sessions
Then reflash your drive with the latest stable image
reflash solve it
Do you mean physically reflashing or launching again hive-replace?
Edit: I revoked all the sessions/tokens and then I executed again hive-replace -s. I still have the issue.
Still not resolved
Revoke any unknown sessions
Check router for any open ports that you’re not using
Try reflashing your drive with the latest stable and changing the system password before connecting back to your network
Again? I already revoked any session and token.
About the router ports, how an open port can make the selfupgrade command not working?
Finally, I’m not able to physically reflash the drive of that machine, it is a remote machine.
So you are telling me that the hive-replace command shouldn’t be used, since it can cause such huge problems.
i would do it as many times as you need to. it sounds like your network is compromised in some way. hive-replace works great, but wont stop a virgin install from being compromised again and again if your network isn’t secure. the goal of someone who gains access to your system is to keep it that way, if they remove selfupgrade and any other easy way to get rid of their access.
