Again & again. Some clarifications for AMD drivers that used in Hive
AMD drivers consist of two parts:
- OpenCL is a CUDA-like library used in Nvidia GPUs. Unfortunately, starting from version 20.45 and higher, the library is unbalanced and some cards lost support (for example Vega), others did not win in any way in terms of hashrate. Therefore, many mining systems and Hive also use the 20.40
- On the other hand, support directly at a low level (consider overclocking) is provided by the kernel-level driver, and it is almost identical to latest in the official package from AMD.
I slightly changed the code of “AMD memory tweak” and compiled it again now when I try to read the timings I get some values (I’m not sure if they are correct) now I have to check the differences in the registers between JESD212 (GDDR5 standard) and JESD250 (GDDR6 standard). At the moment the parameters cannot be set, the program returns that the changes have been saved, but after checking nothing has been changed.
