Thanks for the tip! really helped me with my 6900XT ASRock. Had to change a bit, but it was a great starting point. currently stable at 62.93 MH/s @ 122 watts (down from 155 watts)… now back to my worse buy… Nvidia 3060 Rev 2…
Hi! which HiveOs version ar you running? I have the same 6900 XT ASRock and is not being detected by HiveOs and I cant apply any overclocks!
Hey! Do you know why the name is 6900 XTX and not 6900 XT?
Doing the same overclocks and with this great results!
I think its because 2 AsRock and 2 MSI are OC, except XT.
x2 AsRock 6900xt Formula OC (XTX)
x2 MSI 6900xt Z Gaming (XTX)
x1 MSI 6900xt X Gaming (XT)
It is also the one that consumes less power, so it makes sense
Okey! Mine also is ASRock OC but didn’t know why it appears as 6900 XTX
Thanks again for all the info!
Recently i’ve bought XFX RX 6900 XT and it came out XTX.
Can’t get it work. It shows as Unknown GDDR6.
Does anyone get it work?
Or know a way to suggest?
I’ve already tried to update and downgrade.
when you have 63 Mh’s, do you have original BIOS or flash?
My 6900XT is on way and I not found any BIOS.
Thank’s for your answers.
Moni
Hi Prowennco,
can you help me with a card from me 6900 xt, I can’t get over 58 mh / s I’ve already tried everything
salve ragazzi
ho un problema che mi fa imazzire
io ho 4 amd 6900 xt powercolor memoria Samsung GDDR6 · 113-D41201-XT
3 schede non mi danno problemi. una scheda invece mi segnala 3 o 4 invalid share al giorno
ho provato diversi overclock settings ma non riesco a risolvere il problema
- prima ho cambiato tutti i cavi e i riser
- poi ho montato le 4 gpus su un altra motherboard
la gpu che segnala invalid share è sempre la stessa
ora ho provato a resettare overclock settings ed ho solo settato SoC VDDmax=960 come tutte le altre gpu
non ho risolto il problema
qualcuno sa suggerirmi cosa posso fare?
is it phantom gaming ?
I have a rig with 6900xt, i try to reduce the consume around 100/110 kw but is not so stable… with this settings I don’t have any problem
Any advice to improve?
Has anyone actually measured the true power draw from the wall? Software readings on AMD seem off.
Someone can help me?
Try my oc.
It’s rock stable for me.
62.4mh@94w on TRM.
SoC Frequency 980
SoC VVDMax 806
Kernel #72
Driver 5.11.1001
Thanks. I tried and it seems work. At the moment I made an ibryd with my settings (2 gpu with my oc and 2 with yours) that’s because i need to verify the cost/benefit
My oc 62.90mh with 115w
Yours 62.40mh with 100w
Witch is better?
my efficience is better, yours is 0,547 ; mine 0,624
Yes it’s true. Thank you so much!
I think that it could be the best setting at the moment
