RX 6900 XT overclocking, need help
Mesut, şuan en güncel versiyonu indirip kurduğun zaman kartları tanıyor.
Fakat madenciyi Phoenix seçme, nedense son versiyonu (6 lı sürümleri) çıktıktan sonra 6900xt leri görmüyor. Bu yüzden Teamredminer ı kullanabilirsin.
better OC config ?
you can change Core and VDD. I think that the best value 1075 of MEM
SAD… idk why this…
already try this but never same settings…
I would like to know if you are using your mainbord cpu and flight sheets.
Can you Share your OC plz
Try to set the core voltage 630-645, on of my cards work better with 635 others 645
Which miner are u using?
Nbminer on ethermine pool, I have a stable 63.55 MH on 108W power. Temps 40 and 60 and fans are set to 45%. Very quiet and power efficient! I am quite happy with it.
First time trying oc, mem clock was at 90°, thanks to you i could drop it to 60°, its an MSI X Gaming Trio, any ideas how to keep improving?
config:
Hi, i tryed all configs seen above, but i keep getting invalid shares.
This is my config:
What else can i try? Any suggestion?
Thank you.
DPM?
53MH :roll_eyes:
There’s no DPM.
Did you tried my settings ? I’m getting about 62.4 mhs
Hello, I have Sapphire nitro + RX 6900 XT but I got too many invalid share.
Even with no overclock value, so stock value from the card I got invalid share like every 20 second !
I have try some overclock value but the result is the same
:thinking:
This is my settings :
