RX 5700 XT Overlocking and Undervolting
Can you please share what to do to get those 59 with less than 120w ?
the max i’m getting is 57 on TRM
You will find the modification and testing process documented at https://www.igorslab.de/community/threads/gigabyte-5700-xt-bios-mod-fails.3304/.
AlleyCat
thanks
Not sure to understand what to do in the end…
what i’ve did with slightly better results than i had
  • Replace straps by Apple Straps
  • K4Z80325BC
1000 MHz - 000000005E0C000000000000DA08000040000000101E0F092D000F0004040002100000000606060010000000110806000000010101000101001718003C0F00000A0A000078000000780000004A5156023C0000000C000A0A0F0400011F2A0C00780000004AF3130F7800000000000000
1250 MHz - 000000007E000000000000006A090000400200001426130D3900130006060002140000000607070014000000218A06000000010101000101001B18000B1300000D0D000096000000960000004D5166024B0000000C000A0D130400011F2A0C00960000000AF4130F9600000000000000
1550 MHz - 000000000F040000000000007A09000040030000162D170F4400170006060002180000000708080018000000210C07000000010101000101001C18009D1700000F0F0000B4000000B40000004F5178025A0000000C000A0F150500011F2A0C00B4000000CBF4130FB400000000000000
1800 MHz - 000000000F040000000000007A09000040030000162D170F4400170006060002180000000708080018000000210C07000000010101000101001C18006C1B00000F0F0000B4000000B40000004F5178025A0000000C000A0F150500011F2A0C00B4000000CBF4130FB400000000000000
2000 MHz - 000000001F080000000000000A0900004003000018341B114E001A000808000220000000070909001C000000218E07000000010101000101001E1800781E000012120000D2000000D200000052518602690000000C000A12170500011F2A0C00D20000008BF5130FD200000000000000
2250 MHz - 00000000280C0000000000001A090000400300001A3C1F135A001E000808000220000000080A0A0020000000211008000000010101000101001F18004722000014140000F0000000F000000054519802780000000C000A14190600011F2A0C00F00000004CF6130FF000000000000000
  • MT61K256M32
1000 MHz - 40060000550C0000000000004A090000400000000F19110B28000F00040400020C0000000506060010000000218A05000000010101000101001718003C0F00000A0A000078000000780000008A204C02320000000A00040A0E0300011F2A0C006E000000C2F2130F6E00000000000000
1250 MHz - 0008000065000000000000005A090000400200001120150F33001300060600020C0000000507070014000000210C06000000010101000101001918000B1300000A0A000096000000960000008A205C02400000000A00040A100300011F2A0C008A00000082F3130F8A00000000000000
1550 MHz - 800900007D040000000000006A09000040020000142619133D00170006060002100000000508080018000000218E06000000010101000101001C18009D1700000A0A0000B4000000B40000008A206C024C0000000A00040A130300011F2A0C00A500000002F4130FA500000000000000
1750 MHz - 800900007D040000000000006A09000040020000142619133D00170006060002100000000508080018000000218E06000000010101000101001C1800A91A00000A0A0000B4000000B40000008A206C024C0000000A00040A130300011F2A0C00B400000002F4130FB400000000000000
1800 MHz - 000B00000D08000000000000EA09000040030000162C1D1747001B000808000210000000050909001C000000319006000000010101000101001E18006C1B00000A0A0000D2000000D20000008A207C02580000000A00040A150300011F2A0C00D2000000C2F4130FD200000000000000
1875 MHz - 000B00000D08000000000000EA09000040030000162C1D1747001B000808000210000000050909001C000000319006000000010101000101001E1800931C00000A0A0000D2000000D20000008A207C02580000000A00040A150300011F2A0C00D2000000C2F4130FD200000000000000
2000 MHz - C00B0000150A000000000000FA09000040030000172F1F194C001D000808000214000000050A0A001E000000311207000000010101000101001F1800781E00000A0A0000E1000000E10000008A2084025E0000000A00040A160300011F2A0C00E100000002F5130FE100000000000000
  • Change TRef to 12000 (and 9000 on 2nd memtype) on 1550MHz
  • Copy from 1550MHz to the higher frequencies
  • CORE 1400
  • VDD 770
  • DDDCI 770
  • MVDD 1300
  • MEM 915
result: 56.30MH/s between 100 and 106w
Do you by any chance have your MPT file my rig is on linux only so I can’t use more power tool…
Hola, que son las Apple Straps.
DDVCI en 710 , MEM 860 , MVDD 1270 , CORE 1280 , VDD 750.
prueba esa config, reducira el hash y las temp .
que gpu tenes?
I suggest that you prepare your own MPT based on the stock bios.
I assembled a scrap WIN10 PC for testing and configurations. I do all the card bios mods on the PC. I purchased used parts to keep the cost low.
The issue is that I don’t really want to buy a new motherboard/cpu/ram just for mpt might be faster to open mpt in hexadecimal…
Edit: found a old harddrive to put on the rig with windows
Sapphire Nitro+ Micron + Samsung
Also Sapphire Pulse 5700xt Micron + Samsung Biso and Clocks ?
i’ve been able to flash a rx 5700 xt with rx 5600 xt bios and was getting 41MH/s for 80w wonder if that’s not somewhere we could want to get some straps, mpt
AlleyCat
i have one problem that i see you have it to, of the 6 gpu 3 of then won’t accept more than 900 on the memory, tops its 910 wail the others can go 940/950, its something with the flash of the bios or is it the silicon lottery? if it is silicone, its not too much of a difference between the same model of cards?
Different memories operate at different speeds. You will need to inspect what type of memory your card has.
I have micron memory in all off them and the memory is MT61k256M32 and they only have 1 memory
Господа ,большая просьба к вам,если есть возможность отредактировать биос Микрон.
I believe and sweet spot is different depends on $/kw in your area. In my case, power is very cheap (0.06$/kW) therefore efficiency is not important as long as I maintain temperatures.
@igotek
I have emailed you my stock bios & HiveOS overview, I am currently running 1500 straps. can you please share your biod mod.
I just got a couple of MSI 5700 XT Mechs for free and put them to work. Does anyone else have experience with these? They don’t seem to want to go below 120 W. I’ve modded the bios and they both sit at around the numbers shown in the figure below.
I can bump the Mem up to 950 and it will top out at around 58 MH and 129W. If anyone has been able to get these to run at lower power please share your settings.
how did you mod the bios of your Gigabyte cards?
You need to load an unsigned version of the bios from Sep 2019.
I documented the process at https://www.igorslab.de/community/threads/gigabyte-5700-xt-bios-mod-fails.3304/
I agree with you totally. What’s your OC setting to get below 100W?
I concluded that getting under 100W depends on the GPU. GPUs with Samsung memory tend to run at lower power. I believe that expensive GPU, like the Sapphire Nitro+, will have a better power consumption.
The only card that I was able to achive below 100W is AMD 5700XT Reference card with Samsung memory. All other GPUs with Micron are running between 109 to 114W.
