None !
You should check Youtube Mining Channels !!!
Good Luck !
None !
Good Luck !
I didn’t ask about profibality … I just ask what kind algorithm is the best for those cards where nvidia are worst
I’m searching niche coin to mine
you can use whattomine and hashrate.no to see the hashrates for amd and nvida cards. You can then compare the values. These sites usually don’t show very good power values. If you do a decent job ocing the card, you should get better values for the power
