I tried your configuration but I still have the same problem … any other ideas? Thanks !!
Check bios setup or change mining pool, swap risers, there could be lots of reasons.
what miner are you using? do you use any extra parameter? I still couldn’t solve the problem …
what miner do u use?
TREX last version
Hi guys, can anyone help me with my 3060 and 3070 TI OC settings?
I am changing than from mining ergo to ethereum, but I can’t find goos settings to get a better performance.
I tried some off the settings above, but none of them got good results. What could I be doing wrong?
I am using NBminer 40.1 version
All my GPUs are from Colorful.
Thanks in advance for the help.
Try 900/2500 on 3070ti
Got almost same results, around 53.5 MH/s.
Maybe I would need to change version of something?
Sorry for the unspecific questions, I’m quite new with mining…
refer to my settings. using latest version of t-rex miner and Nvidia driver 470.74
3070 ti : 60-62 MH/s
3060 : 35-36 MH/s
Are you using any LHR specific settings in the miner configuration?
i am using t-rex-ver. v.0.24.8 since longtime on binance pool with accepted ratio 99%, after updating hiveos to the latest version kernel, accepted ratio dropped to 96 - 97%, i revert back the hiveos to the old stable version and rolled back Nvidia driver to the same stable version but nothing changed, anyone faced the same issue ?
this screenshot 2 minutes before upgrade
and now i am getting rejected shares within the first 20 or 50 accepted share.
Thank you.
i am not using any LHR specific settings in the config section, its is the default that comes with t-rex miner
remove power limit, you can easy hit 59-60 mh and move your core clock to 1350
Thank you for your advice but I already hit 60mh. I just don’t know why but MSI Ventus one can’t do 60 Mh. It must be silicone lottery, I guess…
Put that power limit field on 0. You don’t need it and now you’re now limiting the miner software for unlocking your card
Thanks! I have tried with “0” power limit and It improves a bit but Ventus one can not hit to 60 Mh.
