rica ederim.
I used to be like that, but now if all my workers combined are above 99.9% i dont care. More downtime results from tweaking your cards with a doubtful result. Rejected shares will happen from time to time and I think I’ve accepted that
I get invalid shares with this settings, why?
@RWM , Hi , I am new with Hive OS, I can not found command/instruction showing the Summary message you posted, May you please tech me how to do it?
Pretty stable, hot in here tho, outside air is 21°C and inside the room 28°C using 860W at the wall !
Приветствую, с какими именно настройками на EVGA 63,1МХ выдают у тебя?
Noob question
Coming from windows and MSI afterburner…
In MSI for 3070 to OC I put +1300 memory and it gets to 8100MHz
In HiveOS I see all of You setting memory from 2200 to 2XXX what is the memory MHz result with those settings? (looking for a way to set the same settings as they were working in windows with MSI)
Ey In hiveos the memory settings Have a factor 2x compare to windows. So if you filled in 1300 in windows, you should fill in 2600 in hiveos to get the same memory speed.
thanks i was looking this info too.
i want to share my OC… its the most stable that i could find… i can get 62+ but with some errors and rejects… this works 100%…
Yes the ventus is version fro MSI is not as good as the gaming. I am using core at 1080 and mem at almost the same as you. I am still 50 higher, but still getting an error every now and then, so I am still adjusting. the Gaming Trio X can run stable with mem at 2800 so quite a difference.
Have you tried with core at 1080 and PL at 120. Just to save a little power
lower your memory clock… 2800 is pretty high… i had problems with my 3070 at 2200… id start at 2k and work your way up 100 at a time
I don’t have any issues with 2800, previously was running at 2600. at some point the cards reported 65 msh but they were hot af. but 63 is normal temp 50 cpu
There can be a lot of difference in the settings from one card to another. I have a couple of different cards running. An ASUS TUF (the first) A MSI Gaming X trio (2.) And a MSI Ventus (3) And they have different settings as they will else get invalid share every now and then, and I like to avoid that.
You should try to use Absolute core clock for the settings as well. Try set it to 1100 and you will save 50 watts.
T-Rex miner 0.20.3.
Msi 3070 gaming x 2x
GYGABYTE 3070 gaming 2x
Why reject share. T-Rex, nbminer same again.
Most 3070 cards is happies at around 2400 to 2425 mem clock
Last month, everything was fine at 2600.
 thanks man. not 50w but still
