increasing the fans??
even on 100% temp is extremly high
you mean 0 for PL?
Correct
once 1100 core its locked and PL is not longer required
ok, but how to reduce temp?
once cores locked the voltage drops
any good OC for 3070 ETH+TON or ETH+TON+ZIL?
Hey everyone, IDK why my rig gets a bit frustrated when I’m trying to reduce 3090 temps. I split the rig into two frames allowing better cooling and after that “without declaring the war,” it decided to give me some invalid shares. I did reduce memory a bit to see if that’s the issue but no luck. 1 or two shares on some of the GPUs per day.
Anyone can help improve what I have?
Using the latest Lol miner.
sometimes is software related, last time like 1 or 2 t-rex versions ago one of my rigs started to get invalid shares, but i could not see them on pool side only reported on miner software on hiveos, when i switched to gminer there where no invalid for 24h when i switched back to t-rex there where 1-2 per 24h. then the new version came out and problem disapeared.
That sounds about right because I just updated to see my mem temps. The pool shows 100% valid. Thx
I have heard that the core should be divisible by 15 do you know why this is, have you heard this?
most often it is a multiple of 15, but sometimes it goes to weird values
You can check at what speeds your cards are running with nvidia-info |grep Freq
Happening same with me on memory 2600 than I reduced to 2500 and was still get invalid shares, after that I changed to 2400 and it work perfect
some cards don’t want you to set less than 100. You can adjust the power use through the oc.
