RTX 3070 settings
Is it normal to receive Invalid share, if yes can you tell me how many is ‘‘too many’’?
Here is my setting:
I tried those setting too: MEM: 2200 PL: 130
With both setting after 24h-36h I start getting Invalid Share
try on changing pool or pool server
Thats not a memory setting .
That’s within the absolute core clock parameters that HiveOs has implemented about 4 months ago.
Read about it.
It’s called locked core. Trex miner has also added it to their mining parameters.
miss clicked wasn’t for you ahah
that’s high mem, make sure to keep 'em cool
2600 is also not a high memory for a 3070…
Your batting 1000 so far…hahahh
any idea whats going on? try to lower the MC but still get the invalid share
i put dag build mode 2 still same result.
latest trex miner
hi, how do i configure the auto fan for the 3080 evga?
After you “apply” the Auto fan, go into ur current overclocks window and put fan values to “0”.
Is there a problem in the confiuration if I have 1 amd card in the rig?
Just leave that one at the percentage you want in overclocks, thats should work.
But why not set them all to 50-55?
I set it to 52 all and I have a 570 with my 3080 rig where when setting the fan it gets 100% haha
What temps were you running before?
Uploading: 3080.1.jpeg…
Could you help me with this problem, I have a 3080 at that temperature with 95 from the fan (I changed the therma pads)
That doesn’t tell me anything. What’s ur MH on the 3080?
What’s temp in the room?
Where is the GPU located in the rig, is it close to other GPUs?
Show me overclocks
Uploading: 3080.2.jpeg…
If you just had it on a 3, 3080 570 3080 rig in that position with 15cm of space between each one(It is in a living room where it is not cold but it is at a normal room temperature)
Whats ur fan temp set for?
Also, put your core to 1070 on both and memory at 2000
Ok, there I change the oc also I took out the 570 that was in the middle, I configure the car fan?
