Моя цель была добиться максимального хешрейта при минимальной температуре и потреблении.
Карта Palit GeForce RTX 3060 DUAL (LHR) ID 2504 память Samsung. Не вижу смысла жарить карту на 60 градусах и 120PL, получая при этом незначительный прирост в 4-8 мегахешей.
Hello. I do also have a 3060 LHR v2 device id: 2504
I’m trying to mine ergo on my casual pc with latest nvdia drivers 471.41 but i cant mine more than 80 mh/s. my windows is win 10 home.
What should i do to achieve 116-118 Mh/s on Windows
Download MSI afterburner
Slide the power slider down to 65% or 110w (see HWmonitor for power output) add about +1400 on memory and -525 on the core
This gave me 115 Mhs on a Evga 3060 XC3
There is a guy on brandon coin video claiming he has a 2504 and he is mining ETH just fine!
I called BS and asked him to show us his GOD skills! We shall see, I posted as PUSOKONGPINAS if you guys want to see his comments! If there is a way he might have it but he most likely not!
He has retracted his claims now! I didn’t bother reading his excuse! I have no tolerance for haughty attitude!
i think this gpu not LHR, because LHR gpu unable to load on NVIDIA 460.39
Thank you for this summary.
Palit OC RTX 3060 LHR:
Core -248
Memory 2698
Power 100
117.9 Mh/s
Nvidia Driver 465.31
T-Rex 0.21.6
Amd nvidia conflict? I just bought a 3060 v2 lhr card and plugged it into the x16 slot, unfortunately it doesn’t see the video card. 20210823_204030|690x313
Update your Nvidia driver and it will show up correctly.
Unfortunately, when I try to update, the driver does not load. Which nvidia driver do you think I should install?
Thankyou, i got 115Mh/s on gainward 3060 LHR V2
Hİ, What driver version of nvidia did you install on the 3060 cards?
460.39
I finally succeeded, аfter five failed attempts to install 460.39.
try these OC settings for 3060 >> 1255 C, 2900 M, 120 PL
