What values would you use ?
start with 1050 and then if its too low, increase by 50 each step.
This is good. I’ve lowered watts from 487 to 406.
Cards don’t heat up so much. Loosing only 8Mh/s
What would you think of using Bios from none LHR and upload it to LHR version ?
I havent tested but if it works many people would do it. I dont recommend it. If i had such card i would probably test but i am hazzardous person
Hola disculpa la molestia instale todo ayer para empezar a minar con la 3060 y resulta que ahora hay una versión más nueva del controlador como hago para volver para atrás a la versión 460.39 porque tengo la 460.80 y me llega a minar a 26mhs y si quiero hacerlo por windows con la versión 470.05 me dice que la versión de Windows no es compatible y estoy trabado acá si alguien me puede ayudar se los agradecería.
Actualiza HiveOS y usa MiniZ 4 llega a 35
Not to be rude but this is a 3060 model 2504 listing your posting is of the 3060ti which has no consequence unknown to public!
Requesting this to be moved this is a 3060v2 model 2504 discussion! Not a 3060ti discussion which has no unknown issues to public!
Ok my Spanish is really rough but try this
NBMINER 38.2
Driver 466.27
Raven GPU Settings
Core 1360
Memory 8300
Power 75%
Some people above have listed various successful settings for ergo
But 3060v2 is no good for ethereum!
To make sure you have device 2504 check in GPUZ
Good luck!
in the .3 version you can hit 37 and less consumption.
you mean 1.8y3, instead of 1.8y4cr1? let me try that.
you are gonna get loads of bad shares though
try PL 120 it goes up a bit more
good shares
–localtime=11-14
–shares-detail
–extra
–show-mode
0>RTX 3060 [80] ` 100% [ 53°C /59%]* 35.34(35.42)MH/s 106(105.8)W clk=1447MHz mclk=8575MHz MH/W=0.33
using this settings in 3 days
This is what I got from MINIZ still better than Octopus.
