Yes, I think the only reasonable profitability of this card is octopus. I don’t mine cfx so selling it to nicehash for bitcoin.
Hi, did you solved this?
have you tried with absolute core value ?
yes Adamram, i think you are 100% correct considering the current situation for these LHR cards, mine the most profitable in Nicehash and convert the revenue to BTC… ConFlux i was able to make a wallet, but the Binance CFX is on the BSC so could not send the mined coin as a different network
If first gen of LHR (original 3060) only limits ethash and this gen limits also autolykos (3060Ti LHR), next gen LHR will targets octopus and kawpow. Octopus seems the best for LHR right now. Beware of new drivers.
what is your oc setting? it is nicehash?
I got 3060 Ti LHR and i cant get more than 105Mh/s for Ergo, i try everything but i cant get stable and more hash…Sad…
Try typing on the terminal:
nvidia-smi -lgc 1297
Settings:
-200
2700
111
I’ve trying to settle odd wattage and hashrate drops on NBMiner during last 2 weeks and setting L0 on BIOS got rid of it eventually but then I’ve come across this:
Would that explain the random wat drops?
About drop hashrate we comment before. During the ERGO Data Set, that could happen 4 times in a Minute for example, the time creating the Ergo Data Set the GPUs cannot mine. In the photo you can easy see that the calculation of the Mhs in lolMiner is correctly. During last 10s, 1.3s where for the data Ergo Set and the other 8.7S for mining so that makes the Mhs to be reduced. In the other miner the T-Rex that doesn’t happen it also increase the Mhs and it is impossible to mine during that Ergo Data Set. That said the Mhs in T-Rex are not real, the Mhs have to go down during the not mining time for the Data Ergo Set, because is not possible to mine during that time.
I was able to get a stable Hashrate of 124.3m/h mining ergo so far for an hour. With the EVGA 3060ti LHR.
Using HiveOS
NB miner
Driver 365.31
Fan 60
Core 0
Men 1250
PL 120
My settings. Found that MEM is more important than CORE, and that temp swing of 5-10 degrees makes ALL the difference to retain a high hash rate.
Turned off Auto Fan, and manually set fan to 80% was the big change.
My settings:
Ok so I have been reading this all weekend and was able to get stable 116mhs on win64 466.31 nbminer 37.2 no riser solo card kept monitor on as power save affected mining, more on this!
I was successful for 24hrs on 1297/8700/67% 1297core was a sticky point any time it went above 1400core hash would go to hell! I did not pay attention to heat! At is wasn’t a concern at 67%. I thought good one down let’s go do raven on NHM
Moved to inside of NHM nbminer was able to get to 24mh I thought wow ok but here is where it got scary message alerts from inside NBMINER saying something about detected mining blah blah blah no pics unfortunately!
Since then my card would just power down and not awake my monitor states power save mode, once nbminer starts! Scary part is it even continues through reboot I have to do a hard restart which has almost corrupted my HDD no worries it is one of my test benches before I put into into circulation but it’s scary that there is literally code I thing to not want to mine!
Isn’t that almost a infringement on property if I want to mine at a loss that is my personal issue on a product purchase!
My card is EVGA 3060 XC device iD 10DE 2504-3842-3656
Just sharing, this experience has made me not want to touch anything past MAY cards as this was built may 18!
Any suggestions welcome as of this moment I will be cleaning out the computer HDD last resort going to see if I can get image of scary moment in NHM but NBMINER immediately sends comp into power save even before initializing AFTERBURNER, also even if afterburner is initialized!
Try 1312 | 8850 its working for me at 120@100 on P0
how do you get it to run on p0? mine was on p2
@liubros
nvtool -forcestate 1 or 0 last hiveos
Use -242 and then engage the core if 1312 doesn’t work try 1305.
Also you need a bit more temperature on there
been poking around… running a 3090 founders edition… wondering how i can get mine into P0 state…
root@KossBeast:~# nvtool --forcestate 0
HiveOS Nvtool 1.5.0+20210707004635
FORCE P0 STATE: 0
root@KossBeast:~# nvidia-info
Tue Jul 20 15:04:59 EDT 2021
=== GPU 0, 2B:00.0 GeForce RTX 3090 24265 MB ===
Bios 94.02.32.00.02, PCIE Link Gen 2, PCIE Link Width 1x
S/N -, UUID GPU-b57fc83a-72cc-ab6b-bb7d-c41807fefd42
Power Limit: Min 100.0 W, Default 350.0 W, Max 400.0 W, Current 350.0 W
Frequency: GFXCore 960 MHz, MEMCore 9501 MHz
Memory: Total 24265 MB, Used 4715 MB, Free 19549 MB, Micron GDDR6X
Utilization: GPU 100 %, MEM 100 %
PSTATE P2, PWR 257.0 W, Temp 46 °C, Fan 74 %, RPM 1932 (74 %), RPM 1931 (74 %)
