you probably have to put them on 2 separate rigs as they require different drivers
but the question is, do you think that if i update de drivers to the last version the rig its going to detect both cards?
I need to use N 465.31 bcs of RTX 3070Ti, and i am using nbminer v.37.6
This is the best hash i can get, i hope this will help someone bcs lot of people have problem with LHR on new cards…i try everything and i will always get 70mh/s on 3060 but with this settings this is the best for now.
On RTX 3070Ti 160-170mh/s 140-150w u can get but best hash can be about 180
install HiveOS on different USB thumb drives, one for older driver, and one with new driver to test your rig. a usb 3.0 drive is less than $10
I seem stuck after getting the 465.31 driver loaded and finding the 3060 LHR ID of 2504. It does NOT seem to populate the relevant information about the card. I have added and deleted workers and tried other drivers including .27 and not sure where to go. Can anyone give me direction on how to get past the adding of the worker as shown below in HIVEOS? Here is what Hiveos shows… and nothing I seem to do adds it as a actual worker.
Try to update the OS
Thanks… That got it recognized. Now I am on to the forum on why it wont start mining >> No Cards Available for OC!
Mike
Running stable
Are my OC settings ok? I tried locked Core best I could find was 1260 2510 100 and it runs 90W 106.4MH/s
Powerlimit too low.
Try core 1550 memory 2550 powerlimit 130
Tell me your Nvidia driver and NB miner version?
Thank you
I got 109Mh/s with 1250 2600 125 90w
N465.31
nbminer-ver. 38.1
0.6-204@210704
A 20.40 (5.9.0325)
Gigabyte Gaming OC
can i know what is your default hashrate on LHR when mining? i just bought 3060 ti LHR my default hashrate when test on windows 26MH/s . hope can get result like yours.
I found that it must stay at 60C with the lid closed fan at 74 for me. Now I’m running tests with the lid open trying to squeeze it a bit more. Also if I go over 103 W crashes.
I haven’t tried to find the sweet spot on ETH as I haven’t been unable to replicate the 0% fan trick.
This is for Ergo , have you checked for ETH?
What settings are working for RTX 3060 V2 for Ethash?
i found the best profitability for the LHR v2 is on Octopus - ConFlux with T-Rex
3060 - 42.95 MH
3060 ti - 53.52 MH
Core:100 // Mem: 1200&1400 // PL: 140w
Hoping eventually these cards can be opened up with no limiter sometime soon…
I doubt they will be opened with no limiter.
Whats the profitability?
that setting not work for 3060 ti lhr. only can get to 31MH
