Rig Lost WiFI connection and could not reconnect again automatically
How to resolve subject problem.
My rig is connected through wifi with internet. Due to some reason it lost connection but could not reconnected again automatically like windows. Manually I restarted rig and now its connected again.
I don’t know much about linux . .
Any help would be appreciated to resolve this issue.
Me too… any luck with solution
I used ethernet to USB adapter and it works fine now . . .
Thx…ive got mine working on a usb wifi dongle. Seems to be ok now
Have the same problem. I’m using the builtin wifi on the motherboard. It connects fine on boot, but should the wifi fail, it is unable to reconnect.
I have configured these files
/etc/wpa_supplicant/wpa_supplicant.conf
/etc/network/interfaces.d/wlan0
I have the following for /hive-config/network/30-wireless.network
[Match]
Name=w*
[Network]
DHCP=yes
DNS=8.8.8.8
[DHCP]
ClientIdentifier=mac
RouteMetric=20
could there be something wrong in one of the other files in /etc/network/? Maybe something that isn’t compatible with onboard wifi?
Just saw this
systemctl status networking.service
● networking.service - Raise network interfaces
   Loaded: loaded (/lib/systemd/system/networking.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Sun 2022-10-16 13:31:01 CDT; 1h 50min ago
     Docs: man:interfaces(5)
  Process: 599 ExecStart=/sbin/ifup -a --read-environment (code=exited, status=1/FAILURE)
  Process: 590 ExecStartPre=/bin/sh -c [ "$CONFIGURE_INTERFACES" != "no" ] && [ -n "$(ifquery --read-environment --list --exclude=lo)" ] && udevadm sett
 Main PID: 599 (code=exited, status=1/FAILURE)
Oct 16 13:31:01 hive670 wpa_supplicant[679]: rfkill: Cannot get wiphy information
Oct 16 13:31:01 hive670 wpa_supplicant[679]: Could not read interface wlan0 flags: No such device
Oct 16 13:31:01 hive670 wpa_supplicant[679]: WEXT: Could not set interface 'wlan0' UP
Oct 16 13:31:01 hive670 wpa_supplicant[679]: wlan0: Failed to initialize driver interface
Oct 16 13:31:01 hive670 ifup[599]: /etc/network/if-pre-up.d/wpasupplicant: 120: /etc/network/if-pre-up.d/wpasupplicant: cannot create /dev/stderr: No su
Oct 16 13:31:01 hive670 ifup[599]: run-parts: /etc/network/if-pre-up.d/wpasupplicant exited with return code 1
Oct 16 13:31:01 hive670 ifup[599]: Failed to bring up wlan0.
Oct 16 13:31:01 hive670 systemd[1]: networking.service: Main process exited, code=exited, status=1/FAILURE
Oct 16 13:31:01 hive670 systemd[1]: networking.service: Failed with result 'exit-code'.
Oct 16 13:31:01 hive670 systemd[1]: Failed to start Raise network interfaces.
at least this one is working
systemctl status wpa_supplicant
● wpa_supplicant.service - WPA supplicant
   Loaded: loaded (/lib/systemd/system/wpa_supplicant.service; enabled; vendor preset: enabled)
   Active: active (running) since Sun 2022-10-16 13:31:01 CDT; 1h 52min ago
 Main PID: 511 (wpa_supplicant)
    Tasks: 1 (limit: 4915)
   CGroup: /system.slice/wpa_supplicant.service
           └─511 /sbin/wpa_supplicant -u -s -O /run/wpa_supplicant
Oct 16 13:31:01 hive670 systemd[1]: Starting WPA supplicant...
Oct 16 13:31:01 hive670 systemd[1]: Started WPA supplicant.
Oct 16 13:31:01 hive670 wpa_supplicant[511]: Successfully initialized wpa_supplicant
it should try to reconnect every 60 seconds or so. you can set a hashrate watchdog to reboot if it cant reconnect though.
doesn’t do it. I had periods of about 30m, after which I had to restart
I could add a script that checks for the wlan0 state, and try to reconnect, but hive should do this by itself.
If I boot, wifi has no issues. However, if it gets disconnected, it doesn’t know how to reconnect.
Not sure I want the rig to reboot if the network goes down. Sometimes it is an exterior issue (isp, modem, etc.) and the network is fine. The rig would be rebooting for a while if the problem isn’t local
Also my AP isn’t great and would love to restart it once a week, without having my rig restart because the AP was out.
Wouldn’t rebooting and fixing the internet be better than not rebooting and not regaining internet? If you’re having so many network issues I would upgrade your ap and wiring and such.
works well enough for most cases. However, my point was that the rig should be capable of reconnecting by itself. Even my old phone can do that and would presume windoze can do it too. Rebooting shouldn’t be needed to regain wifi, especially since there is already a watchdog routine that should check for that.
Besides, the same behavior happened with the other ap, which is better behaved. Serendipitously, we just had the power flicker. Even stranger the ap went down, but the rig didn’t! Alas, it lost the wifi and had to reset :frowning:
Using this script seems to work.
@keaton_hiveon
The script to reconnect works (see below for one changed for hive). Added a line to be run through crontab. Though I’m confused whether to use crontab -e or edit /hive/etc/crontab.root. I did both lol
However, the system is getting confused about wlan0. At boot, it can’t find it. Either it has a different name and then gets renamed, or it takes a while to come online. So something at a lower level than I want to mess with.
This affects networking.service, thus slowing down the boot process. Since the network interface isn’t being found, the system waits for the network (systemd-networkd-wait-online.service) and that can add a couple of minutes. It also affects resolvconf-pull-resolved.service
Can you also pass this on to the devs? This should solve the problem of people not reconnecting, and hopefully, they find a way to speed up the boot
   Active: failed (Result: exit-code) since Wed 2022-10-19 16:13:40 CDT; 23min ago
  Process: 623 ExecStart=/sbin/ifup -a --read-environment (code=exited, status=1/FAILURE)
  Process: 614 ExecStartPre=/bin/sh -c [ "$CONFIGURE_INTERFACES" != "no" ] && [ -n "$(ifquery --read-environment --list --exclude=lo)" ] && udevadm se
 Main PID: 623 (code=exited, status=1/FAILURE)
hive670 wpa_supplicant[705]: rfkill: Cannot get wiphy information
hive670 wpa_supplicant[705]: Could not read interface wlan0 flags: No such device
hive670 wpa_supplicant[705]: WEXT: Could not set interface 'wlan0' UP
hive670 wpa_supplicant[705]: wlan0: Failed to initialize driver interface
hive670 ifup[623]: /etc/network/if-pre-up.d/wpasupplicant: 120: /etc/network/if-pre-up.d/wpasupplicant: cannot create /dev/stderr: No
hive670 ifup[623]: run-parts: /etc/network/if-pre-up.d/wpasupplicant exited with return code 1
hive670 ifup[623]: Failed to bring up wlan0.
root@hive670:/# ifquery --read-environment --list --exclude=lo
wlan0
root@hive670:/# systemctl restart networking.service
root@hive670:/# systemctl status networking.service
   Active: active (exited) since Wed 2022-10-19 16:38:15 CDT; 5s ago
  Process: 29276 ExecStart=/sbin/ifup -a --read-environment (code=exited, status=0/SUCCESS)
  Process: 29273 ExecStartPre=/bin/sh -c [ "$CONFIGURE_INTERFACES" != "no" ] && [ -n "$(ifquery --read-environment --list --exclude=lo)" ] && udevadm
 Main PID: 29276 (code=exited, status=0/SUCCESS)
hive670 systemd[1]: Starting Raise network interfaces...
hive670 systemd[1]: Started Raise network interfaces.
 systemd-networkd-wait-online.service - Wait for Network to be Configured
   Loaded: loaded (/lib/systemd/system/systemd-networkd-wait-online.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Wed 2022-10-19 16:50:09 CDT; 3min 2s ago
     Docs: man:systemd-networkd-wait-online.service(8)
  Process: 624 ExecStart=/lib/systemd/systemd-networkd-wait-online (code=exited, status=1/FAILURE)
 Main PID: 624 (code=exited, status=1/FAILURE)
hive670 systemd-networkd-wait-online[624]: ignoring: lo
hive670 systemd-networkd-wait-online[624]: managing: wlan0
hive670 systemd-networkd-wait-online[624]: Event loop failed: Connection timed out
hive670 systemd[1]: systemd-networkd-wait-online.service: Main process exited, code=exited, status=1/FAILURE
hive670 systemd[1]: systemd-networkd-wait-online.service: Failed with result 'exit-code'.
hive670 systemd[1]: Failed to start Wait for Network to be Configured.
systemctl status resolvconf-pull-resolved.service
● resolvconf-pull-resolved.service
   Loaded: loaded (/lib/systemd/system/resolvconf-pull-resolved.service; static; vendor preset: enabled)
   Active: failed (Result: start-limit-hit) since Wed 2022-10-19 16:48:16 CDT; 23min ago
  Process: 836 ExecStart=/bin/sh -c cat /run/systemd/resolve/stub-resolv.conf | grep -v edns0 | /sbin/resolvconf -a systemd-resolved (code=exited, sta
 Main PID: 836 (code=exited, status=0/SUCCESS)
hive670 systemd[1]: Starting resolvconf-pull-resolved.service...
hive670 systemd[1]: Started resolvconf-pull-resolved.service.
hive670 systemd[1]: resolvconf-pull-resolved.service: Start request repeated too quickly.
hive670 systemd[1]: resolvconf-pull-resolved.service: Failed with result 'start-limit-hit'.
hive670 systemd[1]: Failed to start resolvconf-pull-resolved.service.
root@hive670:/# systemctl restart resolvconf-pull-resolved.service
root@hive670:/# systemctl status resolvconf-pull-resolved.service
   Active: inactive (dead) since Wed 2022-10-19 17:13:02 CDT; 2s ago
  Process: 4961 ExecStart=/bin/sh -c cat /run/systemd/resolve/stub-resolv.conf | grep -v edns0 | /sbin/resolvconf -a systemd-resolved (code=exited, st
 Main PID: 4961 (code=exited, status=0/SUCCESS)
lshw -C network
  *-network
       description: Wireless interface
       product: QCA6174 802.11ac Wireless Network Adapter
       vendor: Qualcomm Atheros
       physical id: 0
       bus info: pci@00x:x:00.0
       logical name: wlan0
       version: 32
       serial: x:x:x:x:x:23
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=ath10k_pci driverversion=5.10.0-hiveos firmware=WLAN.RM.4.4.1-00079-QCARMSWPZ-1 ip=192.168.x.x latency=0
 link=yes multicast=yes wireless=IEEE 802.11
       resources: irq:149 memory:df200000-df3fffff
  *-network
       description: Ethernet interface
       product: Ethernet Connection (2) I219-V
       vendor: Intel
       physical id: 1f.6
       bus info: pci@00x:x:1f.6
       logical name: eth0
       version: 00
       serial: x:x:x:x:x:9b
       capacity: 1Gbit/s
       width: 32 bits
       clock: 33MHz
       capabilities: pm msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=5.10.0-hiveos firmware=0.2-4 latency=0 link=no multicast=yes port=t
wisted pair
       resources: irq:143 memory:d7100000-d711ffff
the script from before with some changes for hive
#!/bin/bash
SSID=$(/sbin/iwgetid --raw)
if [ -z "$SSID" ]
then
     echo "`date -Is` WiFi interface is down, trying to reconnect" >> /var/log/wifi-log.txt
     sudo ifconfig wlan0 down
     sleep 30
     sudo ifconfig wlan0 up
fi
echo "WiFi check finished"
