В данный момент саппорт предлагает в качестве решения обновление драйверов сетевой карты. Для этого даже есть скрипт в каталоге /hive/opt/e1000e/
I think this is to do with the selection of the api.hiveos
just changed mine, I will test and report back
Can you please explain how you changed API ?
Have the same issue, high pings.
I have the same issue. Every night around 20:55 my rig goes offline and I cant reboot it remotly. I changed the mirror. The Amster doesnt worked today. Next is Helsinki because the one what they proposed is gray for me so I cant choose it. Any idea? I have to change back to other OS if I cant solve it fast…
See my solution in this post
https://forum.hiveos.farm/t/asus-b250-asrock-h110-e1000e-nic-hangs-entire-network-solution/32708
Есть подобная проблема. Риг пропадает из сети. При этом гудит, работает. Удалось подключить монитор. Он работает, что-то делает, но что на нём происходит не ясно.
Кажется разобрался. 2 БП, отваливались карты, ложили риг. Плата со встроенной видеокартой на отдельном блоке. Поэтому HiveOS не мог загрузится нормально. Немного переставил карты. Снизил разгон одной из них и сменил для неё майнер. Пока работает. Буду наблюдать.
Hi any expert can help? i didnt touch any setting all is default, but i notice all the connection host not found. where is the possible setting to set ?
I am seeing in the stats that the rig is offline but no such thing is shown on the pool and from what I can tell the miner is working normally. At the moment the rig is working normally but how to differentiate a real problem from this? I am getting notifications on Telegram that the rig is offline but when I check it it is mining normally.
Rig stats:
Pool side for the same period (disregard a blip in graph its caused by tempering with OC):
My rigs are doing strange things as well. Gaps in the ETHASH graph, that correspond between rigs. Is this a sign the HIVEOS pool servers are going down? I haven’t looked at the logs as yet.
Even the main page is showing errors now:
Although, connecting remotely via VNC, this rig seems to be mining and connecting OK. I have yet to check the other rig.
same issues here, any idea?
i know the rig is working but as said its a bit scary not to know whats wrong and loose the chance to check a real failure.
Something is wrong on the HiveOS server for sure. My rigs are intermittent going on/off line for the past few days. And today is ERROR 500 internal server error when accessing via Chrome. Hope they will fix this soon.
same issue here
there are a lot of other forum posts that complain about the same problem
Damn, i wish i’ve seen your answer earlier today… I’ve been going crazy since this morning and tought it was my USB key that was fcked up, so i reinstalled everything to find out the issue’s still here.
HiveOS isn’t as realiable as few month/years ago…
I have the same issue here, it seems like HiveOS is experiencing troubles.
Hi guys, tonight i preflash the hive OS on new flash and everything is ok now, but i have new problem - >Autofan: GPU temperature 511 is unreal, driver error - and 4 of cards
Can you help with this?
Looks like things have stabilized since mid-afternoon yesterday.
