Try to read correctly the answer… and you will know where are you making the mistake… And more when some Cards come with that mod from factory…
And of course is good to know about silicon lottery… 1.8 ratio
I can’t use this with mixed gpus can I. It’s only for navi
What mvolt do you suggest for soc? 1050 seems to be a little high
I’ve made a 3d printed backplate to hold a 80x80mm PC fan. managed to low 4-6°C degrees on msi 5700xt mech.
