Overclocking issues with MSI Ventus 3x RTX 3090
All,
I have had issues with a few of my MSI Ventus 3x 3090’s and overclocking/underclocking. I have tried every known configuration on the lowest performing cards and cannot get them to go over 110-115MH. In HiveOS it says the throttle on them is POWERLIMIT. The temps on the cards are not super hot and seem on par for a 6 card 3090 rig.
Please see the screenshot below as this is the most stable/best performing settings for my lowest performing cards. Any recommendations would be greatly appreciated.
Note: I have updated Nvidia Drivers and HiveOS versions but to no avail
Switch to locked core clocks on all instead of the negative offsets. You’ll also need more memory to get full hashrate, I typically run mine at 1150/2800. No need for power limits at all.
With locked core clocks on those GPU’s the hashes drop below 100 and if I increase memory on them they drop to around 100-105 range.
Set locked core clocks on all then run nvidia-smi -q And paste the output here
| NVIDIA-SMI 470.94 Driver Version: 470.94 CUDA Version: 11.4 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA GeForce … On | 00000000:01:00.0 On | N/A |
| 99% 54C P2 303W / 320W | 5129MiB / 24267MiB | 100% Default |
| | | N/A |
| 1 NVIDIA GeForce … On | 00000000:03:00.0 Off | N/A |
|100% 53C P2 306W / 350W | 5117MiB / 24268MiB | 100% Default |
| | | N/A |
| 2 NVIDIA GeForce … On | 00000000:04:00.0 Off | N/A |
| 98% 57C P2 313W / 350W | 5117MiB / 24268MiB | 100% Default |
| | | N/A |
| 3 NVIDIA GeForce … On | 00000000:05:00.0 Off | N/A |
| 94% 45C P2 311W / 350W | 5117MiB / 24268MiB | 100% Default |
| | | N/A |
| 4 NVIDIA GeForce … On | 00000000:08:00.0 Off | N/A |
| 97% 52C P2 311W / 320W | 5117MiB / 24268MiB | 100% Default |
| | | N/A |
| 5 NVIDIA GeForce … On | 00000000:09:00.0 Off | N/A |
|100% 53C P2 310W / 320W | 5117MiB / 24268MiB | 100% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| 0 N/A N/A 2102 G /usr/lib/xorg/Xorg 18MiB |
| 0 N/A N/A 3044 C t-rex 5107MiB |
| 1 N/A N/A 2102 G /usr/lib/xorg/Xorg 6MiB |
| 1 N/A N/A 3044 C t-rex 5107MiB |
| 2 N/A N/A 2102 G /usr/lib/xorg/Xorg 6MiB |
| 2 N/A N/A 3044 C t-rex 5107MiB |
| 3 N/A N/A 2102 G /usr/lib/xorg/Xorg 6MiB |
| 3 N/A N/A 3044 C t-rex 5107MiB |
| 4 N/A N/A 2102 G /usr/lib/xorg/Xorg 6MiB |
| 4 N/A N/A 3044 C t-rex 5107MiB |
| 5 N/A N/A 2102 G /usr/lib/xorg/Xorg 6MiB |
| 5 N/A N/A 3044 C t-rex 5107MiB |
I think you forgot to put -q
==============NVSMI LOG==============
Timestamp : Wed Feb 2 22:55:21 2022
Driver Version : 470.94
CUDA Version : 11.4
Attached GPUs : 6
GPU 00000000:01:00.0
Product Name : NVIDIA GeForce RTX 3090
Product Brand : GeForce
Display Mode : Disabled
Display Active : Enabled
Persistence Mode : Enabled
MIG Mode
Current : N/A
Pending : N/A
Accounting Mode : Disabled
Accounting Mode Buffer Size : 4000
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
GPU UUID : GPU-de60c709-5e41-e21e-c63c-ee0b11325d72
Minor Number : 0
VBIOS Version : 94.02.59.00.F2
MultiGPU Board : No
Board ID : 0x100
GPU Part Number : N/A
Module ID : 0
Inforom Version
Image Version : G001.0000.03.03
OEM Object : 2.0
ECC Object : N/A
Power Management Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
GSP Firmware Version : N/A
GPU Virtualization Mode
Virtualization Mode : None
Host VGPU Mode : N/A
IBMNPU
Relaxed Ordering Mode : N/A
PCI
Bus : 0x01
Device : 0x00
Domain : 0x0000
Device Id : 0x220410DE
Bus Id : 00000000:01:00.0
Sub System Id : 0x38811462
GPU Link Info
PCIe Generation
Max : 3
Current : 3
Link Width
Max : 16x
Current : 1x
Bridge Chip
Type : N/A
Firmware : N/A
Replays Since Reset : 56962
Replay Number Rollovers : 0
Tx Throughput : 20000 KB/s
Rx Throughput : 55000 KB/s
Fan Speed : 99 %
Performance State : P2
Clocks Throttle Reasons
Idle : Not Active
Applications Clocks Setting : Not Active
SW Power Cap : Not Active
HW Slowdown : Not Active
HW Thermal Slowdown : Not Active
HW Power Brake Slowdown : Not Active
Sync Boost : Not Active
SW Thermal Slowdown : Not Active
Display Clock Setting : Not Active
FB Memory Usage
Total : 24267 MiB
Used : 5129 MiB
Free : 19138 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 5 MiB
Free : 251 MiB
Compute Mode : Default
Utilization
Gpu : 100 %
Memory : 100 %
Encoder : 0 %
Decoder : 0 %
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
FBC Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
SRAM Correctable : N/A
SRAM Uncorrectable : N/A
DRAM Correctable : N/A
DRAM Uncorrectable : N/A
Aggregate
Retired Pages
Single Bit ECC : N/A
Double Bit ECC : N/A
Pending Page Blacklist : N/A
Remapped Rows : N/A
Temperature
GPU Current Temp : 54 C
GPU Shutdown Temp : 98 C
GPU Slowdown Temp : 95 C
GPU Max Operating Temp : 93 C
GPU Target Temperature : 83 C
Memory Current Temp : N/A
Memory Max Operating Temp : N/A
Power Readings
Power Management : Supported
Power Draw : 304.11 W
Power Limit : 320.00 W
Default Power Limit : 350.00 W
Enforced Power Limit : 320.00 W
Min Power Limit : 100.00 W
Max Power Limit : 350.00 W
Clocks
Graphics : 1170 MHz
SM : 1170 MHz
Memory : 10451 MHz
Video : 1290 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Default Applications Clocks
Graphics : N/A
Memory : N/A
Max Clocks
Graphics : 2130 MHz
SM : 2130 MHz
Memory : 9751 MHz
Video : 1950 MHz
Max Customer Boost Clocks
Graphics : N/A
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
Voltage
Graphics : 725.000 mV
Processes
GPU instance ID : N/A
Compute instance ID : N/A
Process ID : 2102
Type : G
Used GPU Memory : 18 MiB
Process ID : 3044
Type : C
Used GPU Memory : 5107 MiB
GPU 00000000:03:00.0
Display Active : Disabled
MIG Mode
Current : N/A
Pending : N/A
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
GPU UUID : GPU-55493fe6-d29b-f482-e882-ebe2232ea122
Minor Number : 1
MultiGPU Board : No
Board ID : 0x300
Module ID : 0
Inforom Version
OEM Object : 2.0
ECC Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
IBMNPU
PCI
Bus : 0x03
Device : 0x00
Domain : 0x0000
Bus Id : 00000000:03:00.0
GPU Link Info
PCIe Generation
Max : 3
Current : 3
Link Width
Max : 16x
Current : 1x
Bridge Chip
Type : N/A
Firmware : N/A
Replays Since Reset : 217
Tx Throughput : 21000 KB/s
Rx Throughput : 80000 KB/s
Fan Speed : 100 %
Idle : Not Active
SW Power Cap : Active
FB Memory Usage
Total : 24268 MiB
Used : 5117 MiB
Free : 19151 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 5 MiB
Free : 251 MiB
Utilization
Gpu : 100 %
Memory : 100 %
Encoder : 0 %
Decoder : 0 %
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
FBC Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
Aggregate
Retired Pages
Remapped Rows : N/A
Temperature
Power Readings
Power Draw : 305.94 W
Enforced Power Limit : 350.00 W
Clocks
Graphics : 975 MHz
SM : 975 MHz
Memory : 10451 MHz
Video : 1290 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Graphics : N/A
Memory : N/A
Max Clocks
Graphics : 2130 MHz
SM : 2130 MHz
Memory : 9751 MHz
Video : 1950 MHz
Graphics : N/A
Clock Policy
Auto Boost : N/A
Voltage
Graphics : 731.250 mV
Processes
Process ID : 2102
Type : G
Used GPU Memory : 6 MiB
Process ID : 3044
Type : C
GPU 00000000:04:00.0
MIG Mode
Current : N/A
Pending : N/A
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
GPU UUID : GPU-ee659300-e072-2e6a-e682-db8df8062add
Minor Number : 2
MultiGPU Board : No
Board ID : 0x400
Module ID : 0
Inforom Version
OEM Object : 2.0
ECC Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
IBMNPU
PCI
Bus : 0x04
Device : 0x00
Domain : 0x0000
Bus Id : 00000000:04:00.0
GPU Link Info
PCIe Generation
Max : 3
Current : 3
Link Width
Max : 16x
Current : 1x
Bridge Chip
Type : N/A
Firmware : N/A
Replays Since Reset : 21091
Tx Throughput : 19000 KB/s
Rx Throughput : 54000 KB/s
Fan Speed : 97 %
Idle : Not Active
FB Memory Usage
Total : 24268 MiB
Used : 5117 MiB
Free : 19151 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 5 MiB
Free : 251 MiB
Utilization
Gpu : 100 %
Memory : 100 %
Encoder : 0 %
Decoder : 0 %
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
FBC Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
Aggregate
Retired Pages
Remapped Rows : N/A
Temperature
GPU Current Temp : 57 C
Power Readings
Power Draw : 313.05 W
Clocks
Graphics : 1005 MHz
SM : 1005 MHz
Memory : 10451 MHz
Video : 1290 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Graphics : N/A
Memory : N/A
Max Clocks
Graphics : 2130 MHz
SM : 2130 MHz
Memory : 9751 MHz
Video : 1950 MHz
Graphics : N/A
Clock Policy
Auto Boost : N/A
Voltage
Processes
Process ID : 2102
Type : G
Process ID : 3044
Type : C
GPU 00000000:05:00.0
MIG Mode
Current : N/A
Pending : N/A
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
GPU UUID : GPU-d8255473-4319-336c-f358-345c80567733
Minor Number : 3
MultiGPU Board : No
Board ID : 0x500
Module ID : 0
Inforom Version
OEM Object : 2.0
ECC Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
IBMNPU
PCI
Bus : 0x05
Device : 0x00
Domain : 0x0000
Bus Id : 00000000:05:00.0
GPU Link Info
PCIe Generation
Max : 3
Current : 3
Link Width
Max : 16x
Current : 1x
Bridge Chip
Type : N/A
Firmware : N/A
Replays Since Reset : 116
Tx Throughput : 22000 KB/s
Rx Throughput : 60000 KB/s
Fan Speed : 94 %
Idle : Not Active
FB Memory Usage
Total : 24268 MiB
Used : 5117 MiB
Free : 19151 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 5 MiB
Free : 251 MiB
Utilization
Gpu : 100 %
Memory : 100 %
Encoder : 0 %
Decoder : 0 %
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
FBC Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
Aggregate
Retired Pages
Remapped Rows : N/A
Temperature
GPU Current Temp : 45 C
Power Readings
Power Draw : 311.50 W
Clocks
Graphics : 1035 MHz
SM : 1035 MHz
Memory : 10451 MHz
Video : 1290 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Graphics : N/A
Memory : N/A
Max Clocks
Graphics : 2130 MHz
SM : 2130 MHz
Memory : 9751 MHz
Video : 1950 MHz
Graphics : N/A
Clock Policy
Auto Boost : N/A
Voltage
Graphics : 737.500 mV
Processes
Process ID : 2102
Type : G
Process ID : 3044
Type : C
GPU 00000000:08:00.0
MIG Mode
Current : N/A
Pending : N/A
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
GPU UUID : GPU-e39fbea9-2287-fe2c-e3d6-15ad1144ca92
Minor Number : 4
MultiGPU Board : No
Board ID : 0x800
Module ID : 0
Inforom Version
OEM Object : 2.0
ECC Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
IBMNPU
PCI
Bus : 0x08
Device : 0x00
Domain : 0x0000
Bus Id : 00000000:08:00.0
GPU Link Info
PCIe Generation
Max : 3
Current : 3
Link Width
Max : 16x
Current : 1x
Bridge Chip
Type : N/A
Firmware : N/A
Replays Since Reset : 2474
Tx Throughput : 17000 KB/s
Rx Throughput : 47000 KB/s
Fan Speed : 98 %
Idle : Not Active
FB Memory Usage
Total : 24268 MiB
Used : 5117 MiB
Free : 19151 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 5 MiB
Free : 251 MiB
Utilization
Gpu : 100 %
Memory : 100 %
Encoder : 0 %
Decoder : 0 %
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
FBC Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
Aggregate
Retired Pages
Remapped Rows : N/A
Temperature
GPU Current Temp : 52 C
Power Readings
Power Draw : 311.47 W
Clocks
Graphics : 1170 MHz
SM : 1170 MHz
Memory : 10451 MHz
Video : 1290 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Graphics : N/A
Memory : N/A
Max Clocks
Graphics : 2130 MHz
SM : 2130 MHz
Memory : 9751 MHz
Video : 1950 MHz
Graphics : N/A
Clock Policy
Auto Boost : N/A
Voltage
Processes
Process ID : 2102
Type : G
Process ID : 3044
Type : C
GPU 00000000:09:00.0
MIG Mode
Current : N/A
Pending : N/A
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
GPU UUID : GPU-ae5d1abd-1456-0c53-0863-e5e85d0b43db
Minor Number : 5
MultiGPU Board : No
Board ID : 0x900
Module ID : 0
Inforom Version
OEM Object : 2.0
ECC Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
IBMNPU
PCI
Bus : 0x09
Device : 0x00
Domain : 0x0000
Bus Id : 00000000:09:00.0
GPU Link Info
PCIe Generation
Max : 3
Current : 3
Link Width
Max : 16x
Current : 1x
Bridge Chip
Type : N/A
Firmware : N/A
Replays Since Reset : 52
Tx Throughput : 16000 KB/s
Rx Throughput : 56000 KB/s
Fan Speed : 100 %
Idle : Not Active
FB Memory Usage
Total : 24268 MiB
Used : 5117 MiB
Free : 19151 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 5 MiB
Free : 251 MiB
Utilization
Gpu : 100 %
Memory : 100 %
Encoder : 0 %
Decoder : 0 %
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
FBC Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
Aggregate
Retired Pages
Remapped Rows : N/A
Temperature
Power Readings
Power Draw : 310.72 W
Clocks
Graphics : 1170 MHz
SM : 1170 MHz
Memory : 10451 MHz
Video : 1290 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Graphics : N/A
Memory : N/A
Max Clocks
Graphics : 2130 MHz
SM : 2130 MHz
Memory : 9751 MHz
Video : 1950 MHz
Graphics : N/A
Clock Policy
Auto Boost : N/A
Voltage
Processes
Process ID : 2102
Type : G
Process ID : 3044
Type : C
All he GPU’s are set at CC:1175 Memory 1900 in the HiveOS UI.
Set the power limit on each card to match the highest rated power limit under the cards name, in your case all cards are 350w. Try that and let me know if anything changes.
No change at all.
Still showing sw power cap?
yeah still active for those 3 cards.
IDK this is frustrating as I have these 3 cards in a limited power state and 1-2 cards in my other rigs in the same status (same type of card). I’ve spent hours trying different overclock settings with no real gains. I’m stumped on this one.
did you tried different miner?
A little late here as I missed the last reply, but worst case you could try another 3090 bios, that should solve the arbitrary power limitation issue.
I have not, I will try that out this week.
Any updates on this Kafeend? I’ve got exactly the same card and exactly the same issue, I can now also see the vram temps are good so can rule that out for this power limit throttle.
I just checked this on my 2 3090’s. They both had the SW Power Active. I saw another thread that said to remove the power limit itself or set to 0. Then I ran nvidia-smi -q -d PERFORMANCE and it had removed the SW power active. I assume it does a power limit if one is set. Both of mine had it so I cant compare it other than what I did to remove it. It seems your hashrate is farily low as well. Are you running out of actual power from your supply? Mine distributes it odd when I mine kawpow.
Not Really. Have 3 cards that just won’t get above 115 MH. I’m at a loss. I’ve tried different miners and each had the same result.
I’ve been looking around and it seems like quite a popular issue with the ventus particularly. I’ve seen alot of gamers getting more performance (graphics wise) by actually swapping its vbios with a 3090 gigabyte gaming OC.
They both have X2 pcie which I believe is particularly important, the gigabyte has a higher pl with 390w over the 350w ventus. I’m yet to find any info of someone doing this for mining purposes so not sure on results mh/s wise.
It’s goes without saying that this option isn’t to be taken lightly, it comes with the potential to brick your gpu so to even consider it make sure you do you own research and have a stable computer when flashing.
