Running a fresh image, tried on 2 different 8 GPU rigs. Only overclock setting that appears to be applying is the power. Memory and fan settings not applying, although they appear to be registering. My fans seem to be set to auto, and memory is not affected. This used to work perfectly fine on previous builds.
I’ve tried this on both EVGA and Founders edition 8 GPU rigs.
I have even tried building a new OC profile - same results.
Tue May 15 11:39:49 EDT 2018
Detected 8 NVIDIA cards
CLOCK = -20 -50 -30 -30 -30 -30 -20 -20
MEM = 1420 1440 1440 1420 1440 1440 1440 1440
FAN = 55 60 60 60 55 60 65 65
PLIMIT = 99 99 99 99 99 99 99 99
nvidia-persistenced failed to initialize. Check syslog for more details.
Persistence mode is already Enabled for GPU 00000000:01:00.0.
Persistence mode is already Enabled for GPU 00000000:02:00.0.
Persistence mode is already Enabled for GPU 00000000:03:00.0.
Persistence mode is already Enabled for GPU 00000000:04:00.0.
Persistence mode is already Enabled for GPU 00000000:05:00.0.
Persistence mode is already Enabled for GPU 00000000:07:00.0.
Persistence mode is already Enabled for GPU 00000000:08:00.0.
Persistence mode is already Enabled for GPU 00000000:09:00.0.
All done.
=== GPU 0, 01:00.0 GeForce GTX 1070, 98.14 W / 99.00 W (Default 151.00 W) === 11:39:49
Power limit for GPU 00000000:01:00.0 was set to 99.00 W from 99.00 W.
All done.
=== GPU 1, 02:00.0 GeForce GTX 1070, 97.93 W / 99.00 W (Default 151.00 W) === 11:39:49
Power limit for GPU 00000000:02:00.0 was set to 99.00 W from 99.00 W.
All done.
=== GPU 2, 03:00.0 GeForce GTX 1070, 100.02 W / 99.00 W (Default 151.00 W) === 11:39:49
Power limit for GPU 00000000:03:00.0 was set to 99.00 W from 99.00 W.
All done.
=== GPU 3, 04:00.0 GeForce GTX 1070, 99.09 W / 99.00 W (Default 151.00 W) === 11:39:49
Power limit for GPU 00000000:04:00.0 was set to 99.00 W from 99.00 W.
All done.
=== GPU 4, 05:00.0 GeForce GTX 1070, 96.10 W / 99.00 W (Default 151.00 W) === 11:39:50
Power limit for GPU 00000000:05:00.0 was set to 99.00 W from 99.00 W.
All done.
=== GPU 5, 07:00.0 GeForce GTX 1070, 97.31 W / 99.00 W (Default 151.00 W) === 11:39:50
Power limit for GPU 00000000:07:00.0 was set to 99.00 W from 99.00 W.
All done.
=== GPU 6, 08:00.0 GeForce GTX 1070, 99.89 W / 99.00 W (Default 151.00 W) === 11:39:50
Power limit for GPU 00000000:08:00.0 was set to 99.00 W from 99.00 W.
All done.
=== GPU 7, 09:00.0 GeForce GTX 1070, 98.14 W / 99.00 W (Default 151.00 W) === 11:39:50
Power limit for GPU 00000000:09:00.0 was set to 99.00 W from 99.00 W.
All done.
