@digitalworld
You need clean install from image 0.5-53 to resolve this issue
Need help.
cant find the problem i am getting “NVIDIA OC failed”
Fri Apr 16 00:11:48 PKT 2021
Detected 4 NVIDIA cards
GPU BUS ID : 01 03 05 06
CLOCK : 170 150 80 170
MEM : 900 1000 1100 900
PLIMIT : 140 150 220 140
FAN : 65 65 65 65
NVS query error:
=== GPU 0, 01:00.0 GeForce GTX 1070 8119 MB, PL: 115 W, 230 W, 291 W === 00:11:58
SET CLOCKS: 0 MHz
SET POWER LIMIT: 140.0 W
Max Perf mode: 3
(exitcode=1)
=== GPU 1, 03:00.0 GeForce RTX 2070 7982 MB, PL: 125 W, 175 W, 200 W === 00:12:20
SET CLOCKS: 0 MHz
SET POWER LIMIT: 150.0 W
Max Perf mode: 4
Attribute ‘GPUPowerMizerMode’ (MiningRig1:0[gpu:1]) assigned value 1.
Attribute ‘GPUFanControlState’ (MiningRig1:0[gpu:1]) assigned value 1.
Attribute ‘GPUTargetFanSpeed’ (MiningRig1:0[fan:1]) assigned value 65.
Attribute ‘GPUGraphicsClockOffset’ (MiningRig1:0[gpu:1]) assigned value
150.
Attribute ‘GPUMemoryTransferRateOffset’ (MiningRig1:0[gpu:1]) assigned
value 1000.
=== GPU 2, 05:00.0 GeForce GTX 1080 Ti 11178 MB, PL: 125 W, 250 W, 300 W === 00:12:27
SET CLOCKS: 0 MHz
SET POWER LIMIT: 220.0 W
Max Perf mode: 3
Attribute ‘GPUPowerMizerMode’ (MiningRig1:0[gpu:2]) assigned value 1.
Attribute ‘GPUFanControlState’ (MiningRig1:0[gpu:2]) assigned value 1.
Attribute ‘GPUTargetFanSpeed’ (MiningRig1:0[fan:2]) assigned value 65.
Attribute ‘GPUGraphicsClockOffset’ (MiningRig1:0[gpu:2]) assigned value
80.
Attribute ‘GPUMemoryTransferRateOffset’ (MiningRig1:0[gpu:2]) assigned
value 1100.
=== GPU 3, 06:00.0 GeForce GTX 1070 8119 MB, PL: 90 W, 180 W, 200 W === 00:12:27
SET CLOCKS: 0 MHz
Max Perf mode: 3
Attribute ‘GPUPowerMizerMode’ (MiningRig1:0[gpu:3]) assigned value 1.
Attribute ‘GPUFanControlState’ (MiningRig1:0[gpu:3]) assigned value 1.
Attribute ‘GPUTargetFanSpeed’ (MiningRig1:0[fan:3]) assigned value 65.
Attribute ‘GPUGraphicsClockOffset’ (MiningRig1:0[gpu:3]) assigned value
170.
Attribute ‘GPUMemoryTransferRateOffset’ (MiningRig1:0[gpu:3]) assigned
value 900.
