OC values for GTX 1050 1060 1070
hey guys!
i just freshly put together my first rig with these cards:
Asus GTX 1050 TI 4gb
Asus GTX 1060 OC Dual 6gb
Asus GTX 1070 8gb
my question is what OC values did yall put in that are safely getting out the maximum of these cards?
it all depends on what you want to mine. other settings are for crypto, others for ethash others for equihash.
what would you recommend for equihash?
1050ti
core: 160
mem: 1600
power: 53-60
1060
core: 120
mem: 900
power: 100
1070
core: 150
mem: 1200
power: 130
will it not be a problem that the power limits are below the deafult values?
i mean if you raise the output of the GPUs, are they not using more power?
look at hive what power limits on the card - in my case I’ve
1050ti:
52.5w, 75w, 75w
etc, power limit should be between min value (52.5) and max value (75w)
yepp i have the same. thank you for the help
hmm if i put my 1070 to those settings it keeps freezing up my rig
what memory?
manufacturer?
You should look for the optimal setting for your card. Each card may have different settings due to memory and manufacturer
its asus rog strix gtx 1070 8gb
try mem ~1100 - you must trying low/more core/mem.
If you wan’t add me access, I’ll help you
i did it. get around 980-1000 sol from the 3 cards now. is that fine?
~400 sol per card you should have
How could all the cards pull the same sol when they are different?
ah :slight_smile:
~400 - 1070
~200 - 1050ti
Help! Can you give me the specs of OC 1060 3G hynix and samung mining ETC? thanks!
