I have the same issue. I use Hivepool and get ~3% stale share. With ethermine.org, <.5% stale share. I think I may move my miners to ethmine and just pay the fee.
Can someone share stock VBIOS of DUAL-RX580-O8G Hynix memory?
SK Hynix H5GQ8H24MJR · 115-D009PI2-101
hello, is it possible to share oc settings
thanks
thank you amon49.
Unfortunately it doesn’t work, I am still getting “amdgpu can’t be initialized 0 (error -43)”
Even though that’s my GPU…
Test on your desktop with windows.
This is the original BIOS for my ASUS RX-580 DUAL OC 8Gb Hynix.
I had a problem with this card, refused to start on HIVEOS.
Again flash  the original BIOS, benchmark on desktop for more than 12h; worked perfectly, without any artifact or crash.
But for mining it didn’t work (???).
Maybe it’s your case.
These cards are very bad for mining. Bad memory, not go up, and very very weak cooling solution.
Thanks for sharing this!
I will try on windows and try the benchmark too.
I realized that they are not good for mining, but already bought them…
Is there anyone that use the SAPHIRE NITRO+ RX 580 8G G5 Special Edition please ?
I need the OC settings please if someone use it.
I don’t care about the watt consume… just need to be stabil cause the rig is in another country
and I have only remote acces, so I don’t want to broke something
Thanks all in advance
Denis
hi lello, can i get your bios flash ? my RX580 4GB is only 10 MH/s
Can anyone give me good OC settings for XFX Rx 570 8Gb and ASROCK Rx 580 8Gb. I can’t get the settings right, I get invalid shares and the hashes are bouncing up and down.
did you bios mod your cards, and if so, would you mind sharing how you did it?
I have tried using the polaris one click to mod the bios but once i start mining the miner crashes. any help is appreciated
This is what I have for now on my 4 cards Saphire RX580 Special Edition:
In the next days I’ll try the B-Mode in order to see if there is more hash.
Denis
I’ve updated my bios on my cards and I can’t get anything over 21
Can someone help me with my settings? Thank you…
Try the following for your RX 580 Asus
Core 1125
VDD/VDDCI 900
MEM 2000
REF 30
PL 75
Thank you I’ll try it!
Did you update your bios? I did I don’t think I should have.
Thank you for your help!
hi
can someone help me please
i have an MSI RX 580 ARMOR SP 8G and i cant mine with it for 2 min
hashrate not stable sometime 5mh and sometime 20mh
i think the card have the stock BIOS
i search for a moded bios… but i’m confused
if someone can help me please.
thank you
Radeon RX 580  · MSI
SK Hynix H5GQ8H24MJR · 113-V34122-F3
Hi i got rx 580 xfx 8 gb samsung memory modes bios my settings are
Fan 70
Core 1150
Dpm 5
Vod 900
Mem 2100
Ref 0
On some of the cards i gets wrong calculations do you know what i can fix ???
