cool youre GPUs ASAP
What miner are you use to mine ?
I have a card MSI RX580 8GB with Samsung memory
I make the flash bios using PolarisBiosEditor one click
but I can do max 28.xx mh
Is there anybody that have the same card
in rder t share the settings please ?
Thanks in advance
Denis
Hi DenisJ, i have the same card… But i start my mining today, when i have better i post my config here.
Wow those are awesome numbers!! I’m trying it now.
Hello my Friends,
You can Download Bios for Hynix and Micron. Update with HIVE OS than overclock and Run.
http://kiffycat.ch/space/kiffycat-radeon-rx580-double-Bios.zip
Kiffycat
ok
Thanks a lot
Hi !!!
I share my OC for AMD RX 580 Samsung memory with bios mod.
Thanks to all to share ! (PS: I have 30°C/86° F outside temperature)
Hi Netiya,
Can you share your BIOS ROM file?
Can somebody share BIOS ROM file for MSI RX570 8GB with Micron memory? Thank you
Hey, i am looking for an modded Bios with untervolting and straps for my graphiccards:
MSI Armor RX580 8GB OC Micron MT51J256M32 · 113-MSITV341MH.653
ASUS Dual RX580 8GB OC SK Hynix H5GQ8H24MJR · 115-D009PI2-101
The Asus Dual has stock as good Hashrates 30.5 MH/s on Phoenix. But Power Consumption is little bit high, so circa 110 Watt and littlebit hot, 70° degrees. I wanna reduce the consumption and temperature a little bit with min. 30MH/s
I cannot find a correct Bios :(, can anyone help me?
Thanks in advance !!!
regards domo
Do you mean, my graphiccards are already bios flashed for mining?
No, I meant that there you can find the bios mod
Anyone idea to reduce the power consumtion, is this clock ok? Vdd ok? Has anyone a GPU BIOS File for reduce power consumption?
Power from wall is 940W with this setup
lol, gpu0 after ca 10 min, 2 invalid share …
Core 1150 Vdd 850 mem 2100 …
For each card play with this at start point…
