Very nice results, could you share the bios settings that you used in order to achieve this watts.
Bests,
Nerheim,
Are you running the stock Bios or custom? I’m running the same cards and am only getting 26.32 MH.
undervolt with 30 men
also go to the phoenix miner btc site
https://bitcointalk.org/index.php?topic=2647654.0
input settings of
I have same card can you please share your cards OC settings and please let me know these cards or vbios moded or not. How much you are able to achieve hash in stable condition. thank you very much in advance.
Hey
, you can go upto mem 2250, check how much mem in use (like 95%) if it is less than 98 or 99 then increase MEM and set DPM to 1.
how to check mem in use ?
for rx570… have this numbers…
your load is 100%… i am not sure you can do anything here.
Great… Which mining algorithm(claymore) are you using?
with phoenixminer… on ethermine… and i change to Hivepool but is with some problems to much rejected share…but the cards work ok… good luck
Bios ?
