Да только ядра, рекомендую на память кроме эльпиды ставить 875, эльпида просит больше, и я не как не могу подобрать эталон т.к. не имею карт с такой памятью.
What are your OC settings to get 32.5mh/s
I have Radeon RX 580 8192M · XFX 8GB card
SK Hynix H5GQ8H24MJR 113-58085SHB1-W91
Thanks i am getting 31.50 now and yes i flashed my bios.
Thank you @BiosEditor for sharing your AMD OC settings for RX580. Can you please share what is your total power consumption for this settings? How long it has been mining stable %100?
Thank you.
Hi . I have 5 AMD 7850 saphire 2 gb and I take an error like this : argument “–mem-clock” requires a parameters and under line this : Unable to read header from file ? Do you have a solution to fixit that
I think you have exceeded the minimum dag file memory requirement. 2gb gpu won’t be supported by many algorithms. Upgrade your gpu to a higher memory. Minimum of 4gb might stay with you for a while and then phase out again. I recommend 6-8 gb gpu. Good luck Mining.
Which miner you are using claymore or ethminer?
You are getting rejected shares so i would decrease memory clock to 2100 to see if it gets better.
i use claymore. i try the 2100. thanks!
to be in a safe side , most rx480 cards memory is 2000
so i suggest to keep it 2000 and let it run for several hours, then increase by 50 and keep it running for several hours , till u see the best hashrate that doesn’t give errors
@Leslie
Thank you so much! i will try it!
Hi Leslie did you mod the GPU ?
Hi Peeps,
i did it, but not perfect. You have some solution?
thx,
Leslie
Добрый день а не подскажите разгон на armor 580 msi Micron MT51J256M32 пишет. а то больше 27 никак не получилось
1100 1 850 2100 is better
I use 1100 1 850 2230 on my Radeon RX 580 8192M · PowerColor Samsung K4G80325FB 113-C9403100_101 cards. 29.69 Mh each
And I use 1100 1 850 2020 or 1900 on my Radeon RX 580 4096M · ASUS Elpida EDW4032BABG 115-D009PI2-101 cards (one of them is fine at 2020, but the other starts throwing bad shares unless I’m down at 1900 - just depends on the quality of the RAM. 26.89 Mh on one and 25.54 Mh on the other.
Total on this rig, 4 cards, 112 Mh.
how long does image filash OK??
