Any help is appreciated!
i 17:24:57 ethminer Connection remotely closed by eth.hiveon.com
i 17:24:57 ethminer Disconnected from eth.hiveon.com:24443
i 17:24:57 ethminer No connection. Suspend mining …
Don’t use ethminer  it’s outdated and unsupported. Which cards are you using? I can recommend some miners that are best suited for your hardware.
Right now, I just have 1 GeForce RTX 3060. I will be adding more once I can get it configured and working. Would entertain suggestions on future cards.
Currently lolminer offers the highest unlock for those, you have no core or memory clocks set, so results won’t be optimal. Trex miner is a close second.
In addition to Keaton’s suggestion to set overclocking, the miner is running 55 seconds in your screen shot.
Some baseline research for this GPU and future adds:
The miner log looks MUCH better now but I see this error:
Set Ethash stratum mode: Ethereum Proxy
Error: Worker not authorized: 3LhAzFXzJgSQYrUV4kRnPJjboquAgohwz4.Rig_5050110_____2287487_5050110
Authorization problem on all configured pools
Terminating lolMiner
Looks like you don’t have an ethereum address set in your eth wallet.
Here is the current error:
Error: Worker not authorized: [wallet ID].Rig_5050110_____2287487_5050110
I replaced my wallet ID in the error with: [wallet ID]
Post a screenshot of your eth wallet address, I don’t think you’re using a correct address.
Yeah, that’s not an ethereum address. You need to use an ethereum address from an ethereum wallet you control there.
OK, I hate to be the FNG here but I thought the coinbase wallet would do that. If not, what would you recommend?
Coinbase wallet would work, but you need to make sure you’re using an ethereum address. It should start with 0x.
OK, now with that silliness behind me, this is the current miner log:
Statistics (20:45:35); Uptime: 0h 10m 0s
The api is active on port 44444
Algorithm 1: Ethash
Connected to: eth.hiveon.com:24443
Algorithm 2: Etchash
Connected to:
  Name     Speed  Pool  Shares   Best    Eff.  Speed  Pool
            Mh/s  Mh/s  A/S/Hw  Share  Mh/s/W   Mh/s  Mh/s
Total 0.00 0.00 0/0/0 0.0 0.000 0.00 0.00
    Shares   Best    Eff.  Power  CCLK  MCLK  Core  Fan
    A/S/Hw  Share  Mh/s/W      W   MHz   MHz  Temp  Pct
Total 0/0/0 0.0 0.000 39.0
Can you show your worker overview screen and your flight sheet?
