did you try measured it on the wall?
mine is the same ranged as before 110 - 130 for 3060ti 100 - 120 for 3060 V2.
Hi! Ive a 3060ti Hynnix to, 1450core/1800mem doing 42,5/43mh but the hiveOS inform 135-145w, how do you get 110-130w?
Unfortunately, I can only manage to pull 130 for Samsung mem. (I caped at 135 for some space upward but it usually varies between 110 - 130)
Hynix drains a little bit higher cap at 140
Ok, then is simillar to my 3060 ti, what driver are you using? thanks!
I am using 470.74.
But now Iâm putting all my Hynix on the market to buy Samsung mem instead, the gap seems to be even greater for each unlocked.
Yeah its true, but its just pure luck on what to get, seems gigabyte cards have all samsung
Yes I tried inno3d Asus evga all hynix.
Hi
yes, for sure I reversed back to T-Rex with this specific rig and the power usage went up again to 129 Watts⌠back to NBMiner 39.6 guess whatâ:interrobang:
Right, 42 Watt power usage from the 3070
Before it said nearly 430 Watts⌠but from totally 12 mixed GPUs itâs just this one 3070 with such low wattage
At the same wall plug is the rig, router, switch, LEDs and a small ventilation⌠nothing more.
And the 3070 does shares enough
Is it possible to get 40 using rig de Palit 3060 ti v2?
If anyone is using it, can you post the screen ss?
I would LOVE to use these other miners but I am mining ETH (NVIDIA cards) & RVN (AMD cards) with my multi gpu setup.
Anyone have any tips for using NBMiner in such a way? Last resort of course is to just mine ETH and trade for RVN.
Yes nbminer working very good and stable on NVIDIA 3070ti after 24hrs observationâŚcompare with lolminer. This my result.
Just try, combine more than one miner. I use gminer for amd and nbminer for nvidia
I have been use them for a few hours and looks great!! I will give You more info later. Thank you. Greetings.
My stats after 1d 2h.
5.4.0-hiveos #140 driver 470.74
3070ti can do 59-62mh at 190-200w, 3060ti 45-46 at 140-150w. (software realtime watts are +15-20)
Great performance for 1350 cclock, also 2200mem for hynix is incredibleâŚ
which brand are you 3060ti? (Hinyx)
Any extra param on NBminer?
-lhr at 75 for all cards the model is ftw3 ultra
I donât have 3070ti but saw many people push it to 60 MH/s !
My hynixs crash even with 1700.
your hashrate is awesome
3070ti nvidia on my rig donât wants level up 53mhs
how much is your PL ?
Can you tell your full OC please
Sorry if i write fault iâm french
