Dear community
I just run a test on the new 39.6 NB miner advertised to be 74% unlocked LHR and it just worked,
Here are my results for 3060TI Samsung mem.
Dear community
What is the exact line to write in Config?
You don’t need to write anything it’s fully automatic.
What the different between lhr mode 1
lhr mode 2 ?
lhr-mode 1 → 74, lhr-mode 2 → 71,
So the default is this mode 2 ,Even if you do not register it it works on lhr 74?
Default is lhr-mode 1 here is full log :
Blockquote * NBMiner v39.6 (significant improvement
ethashLHR mode: higher hashrate, more stable LHR unlocking, default LHR mode changes to lhr-mode 1 for LHR GPUs, default values of LHR mode increased, lhr-mode 1 → 74, lhr-mode 2 → 71, added 3 new options for LHR auto-tuning control:lhr-reduce-value,lhr-reduce-time,lhr-reduce-limitin most cases you do not need to change them, see the miner’s manual for details; adapted forergothe 3 new LHR options as forethash; disabled SNI extension for SSL connections by default, can be enabled withenable-snioption; removed supportcuckatoo&cuckatoo32algos)
请问你的卡是什么品牌的
any crashes with that mem at 2700? I have a hard time keeping them stable there. I have 5 3060’s with samsung mem
3060TI mem 2800 Crash after 2-hour test now at 2650 & 2600.
But 3060 looks quite stable on mem 2700.
How is the power surges? Does the wattage jump up and down as before or is it stable? Lolminer is a 15watt diviation for me, sometimes jumps from 130 to 114 on 3060ti hynix and 105 to 90 on 3060 samsung, both asus.
Lolminer power jumps between 188/175 watt
Nbminer power jumps between 187/172 watt
Ty so much bud. Will try Nbminer now.
linkindog- do you have any hynix 3060ti? I can’t push those nearly has far as a samsung. some are 1500 mem max
Same here.
True, after having no internet for nearly 12 hours yesterday I started up all rigs this night and saw a video of Brandon Coin on YT. After this I tried NBMiner in the newest version et voila it’s so significant better than T-Rex 0.24.5 that I used until then. Before I had totaly 520 MH/s now it’s 545 MH/s!
BTW: does NBMiner something to decrease power usage?
My RTX 3070 Non-LHR used normaly ca. 130 Watt with T-Rex 0.24.5 at 62 MH/s. Now with NBMiner it’s just 42 (!) Watt at exactly 62 MH/s…
WTH?
I have Hynix 3060ti , it is stuck between 43 - 43.5, as always for Hynix 3-4% lower compared to Samsung.
Hynix 3060 TI is well known for limited memory overclocked, but it’s the best for ergo mining stability and power efficiency.
