I´m using one of your OC settings, 1250 725/750/1325 915
but sometimes one card DEAD.
Which is your actual OC settings?
Thx.
Which is your DRAMTiming12 value?
I´m using x2 for 1550 and higher up on both memory types with RBE for only BIOS MOD.
Thx.
I´ve followed your exact instructions,
Are you using Teamredminer?
Thx.
tried to set --eth_config = B608 but the miner does not boot … What would be the correct way to insert the gpu 5700xt id = 5 I tried --eth_config = B608 5 but the miner does not boot I also tried --eth_config = B608 not sucess
