Mining ERGO with Vega 56 & 64
@Zr7s the 64s use quite a bit more wattage, which is why you see so many people flash to the 56, same performance with less wattage.
But if you are running the 64 bios you need to treat the card a little different. Mainly you need memory at 960 and leave SOC blank. with 960 mem that setting should get like 175-180.
@ikledude Ya I agree with LC 1440 / 960 or 1407 /930 if you want to turn some cards up.
for dropping wattage, i’d just try 861 vdd and any that crash get 868…875. Any that stay up for a day there get 855…850.
Ok this will be a 2 post reply here what I was running and results
hmmm, so I’m thinking the 56 straps are too tight for the 64. Maybe try something like this??
–CL 20 --RAS 30 --RCDRD 14 --RCDWR 12 --RC 42 --RP 14 --RRDS 3
–RRDL 6 --RTP 5 --FAW 12 --CWL 8 --WTRS 4 --WTRL 9 --WR 14
–REF 17000 --RFC 249
Or how does it run with no straps?
So just found something about the “bad cards” that is mentioned a bit in the TRM guide. If you run the command amd-info through the hiveos webportal
Then click it once it finishes, you will see that the cards that are under preforming have true effective core value much lower than what its set at.
Looking at these two card’s:
the hashrates make more sence when looking at effective core
Pretty sure this is the “absurd scaling” mentioned in the max hash section of the TRM guide. So only way to improve those will be increase core more.
GPU 3 is my worst example of underperforming the set OCs but even with effective core only running at 1267 it needs nearly 900 vdd, ill have to see how much power it takes to get effective core up to 1300, guessing ill set core to ~ 1380
Update: my cards running RC 37, mem 847 (2 & 5) do not benefit pushing effective core above 1280, 1280 and 1300 both hash at ~179, below 1280 hash drops. So running got those at 1280 & 1277.
GPU 3 running RC 36 did see +8Mh increasing effective core from 1267 to 1300, but it cost 7 watts so not great.
Can confirm that , my hynix msi 56 blower card - is a bad one.
i have also been doing some testing with straps
all other 4 cards are around the 190mhs - with these straps ( samsung memory )
Tried these on the samsungs with mixed results
amdmemtweak --CL 20 --RC 36 --RP 11 --WR 14 --CWL 8 --FAW 12 --RAS 20 --REF 65535 --RFC 248 --RTP 5 --RRDL 6 --RRDS 3 --WTRL 9 --WTRS 4 --RCDRD 13 --RCDWR 12 TESTED - give 1mhs less
amdmemtweak --CL 20 --RC 37 --RP 11 --WR 14 --CWL 8 --FAW 12 --RAS 20 --REF 65535 --RFC 248 --RTP 5 --RRDL 6 --RRDS 3 --WTRL 9 --WTRS 4 --RCDRD 13 --RCDWR 12 TESTED - gave about 4mhs less
amdmemtweak --CL 20 --RC 37 --RP 11 --WR 14 --CWL 8 --FAW 12 --RAS 20 --REF 65535 --RFC 248 --RTP 5 --RRDL 6 --RRDS 3 --WTRL 9 --WTRS 4 --RCDRD 12 --RCDWR 12 TESTED - gives 3mhs less
I have tried numerous straps for the hynix with no success …
amdmemtweak --CL 20 --RC 37 --RP 13 --WR 14 --CWL 8 --FAW 12 --RAS 22 --REF 65535 --RFC 239 --RTP 5 --RRDL 6 --RRDS 3 --WTRL 9 --WTRS 4 --RCDRD 19 --RCDWR 14 - 2 ( ran abit seems ok 177-178mhs)( running 1350/900/900)
amdmemtweak --CL 20 --RC 35 --RP 13 --WR 14 --CWL 8 --FAW 12 --RAS 22 --REF 65535 --RFC 239 --RTP 5 --RRDL 6 --RRDS 3 --WTRL 9 --WTRS 4 --RCDRD 19 --RCDWR 14 - 2 appears to make no mhs diff
amdmemtweak --CL 20 --RC 36 --RP 13 --WR 14 --CWL 8 --FAW 12 --RAS 22 --REF 65535 --RFC 239 --RTP 5 --RRDL 6 --RRDS 3 --WTRL 9 --WTRS 4 --RCDRD 19 --RCDWR 14 - 2 appears to make no mhs diff
amdmemtweak --CL 20 --RC 34 --RP 13 --WR 14 --CWL 8 --FAW 12 --RAS 22 --REF 65535 --RFC 239 --RTP 5 --RRDL 6 --RRDS 3 --WTRL 9 --WTRS 4 --RCDRD 19 --RCDWR 14 - 2 appears to make no mhs diff
amdmemtweak --CL 20 --RC 36 --RP 13 --WR 14 --CWL 8 --FAW 12 --RAS 22 --REF 65535 --RFC 239 --RTP 5 --RRDL 6 --RRDS 3 --WTRL 9 --WTRS 4 --RCDRD 18 --RCDWR 14 - 2 appears to make no mhs diff
amdmemtweak --CL 20 --RC 35 --RP 13 --WR 14 --CWL 8 --FAW 12 --RAS 22 --REF 65535 --RFC 239 --RTP 5 --RRDL 6 --RRDS 3 --WTRL 9 --WTRS 4 --RCDRD 18 --RCDWR 14 - 2 died
amdmemtweak --CL 20 --RC 37 --RP 13 --WR 14 --CWL 8 --FAW 12 --RAS 22 --REF 65535 --RFC 239 --RTP 5 --RRDL 6 --RRDS 3 --WTRL 9 --WTRS 4 --RCDRD 18 --RCDWR 14 - 2 died
amdmemtweak --CL 20 --RC 34 --RP 13 --WR 14 --CWL 8 --FAW 12 --RAS 22 --REF 65535 --RFC 239 --RTP 5 --RRDL 6 --RRDS 3 --WTRL 9 --WTRS 4 --RCDRD 18 --RCDWR 14 - 2 died
amdmemtweak --CL 20 --RAS 30 --RCDRD 14 --RCDWR 12 --RC 42 --RP 14 --RRDS 3 --RRDL 6 --RTP 5 --FAW 12 --CWL 8 --WTRS 4 --WTRL 9 --WR 14 --REF 17000 --RFC 249 - 2 died
I have tried turning up the Core/Mem on the samsungs with no success. i could try the VDD but im comfortable for the time being with the MHS and Watts - would allways like them lower but i find at they crash with less VDD .
Just a note that I’ve found HiveOS 0.6-204 to be very unstable. It especially likes to crash every 2 min especially while I’m sleeping.
I’ve rolled back to 0.6-203 for now.
I’ve been playing around with straps and core clocks on my 7x Vega rig and found that they either prefer mem at 900 or 849.
My Hynix cards seem to be ok on RC 35.
I tried various combos this morning with the aim of 200 but only got up to 195.*~MH 1400/900/960.
  • 190.4 to 195 MH pushed the Wattage up 11.5W per card (at the wall, 92W for 8 cards).
  • thus also increased temps by 2deg C. per card.
  • a few rejected and one card with hardware rejected (the usual suspect card/memory; I could change the --RC 36/37 to resolve).
This may go back to the initial findings a few months ago it wasn’t worth the extra power required. :thinking:
My quick test this morning at 1420/1440 failed. :confounded:
  • I still need to try VDD above 905 up and keep memory down to save on the errors and memory heat. ​
    Before I continue I need to make sure I’m not pulling too much from one of the PSU’s… :grimacing:
Hello guys, I mined a little bit of Ergo in May, and wanted to continue the job.
All my Vega 64 @ 56 can work easy at 170MH/s, but my Vega 56 it’s only working at 80MHs. I think I’ll have to divide the rig in two… Because mining ergo a 80MHs is not worth, I prefere Etherem.
I’m not paying attention to what HiveOs says about Ergo, I only care about pool report. With high clocks I can go over 200MHs according to HiveOs, but the real performance goes down.
Ya I was messing with the 203 Mh settings yesterday but its 3-4 vdd settings higher then my 198 setting so 5Mh costing 12 additional watts on both cards i tested.
If you do the math its still profitable to increase MH even with that bad of a Hash per watt.
12w x 24 hrs = .288kw/hr x $0.11 per kw.hr = 2.9 cents additional cost
additional 5Mh revenue currently = 12 cents per day
But its too hot out so going with 198 and only on the cards with great cooling.
I found that the effective core has a sweet spot for each memory level and going beyond that provides no additional hash, but often being 10-20 core below the optimal level can result in 1 to 3 less MH at same wattage. More for my notes later but here are the sweetspots I found.
203MH
  • amdmemtweak --CL 20 --RC 36 --RP 11 --WR 14 --CWL 8 --FAW 12 --RAS 20 --REF 65535 --RFC 248 --RTP 5 --RRDL 6 --RRDS 3 --WTRL 9 --WTRS 4 --RCDRD 12 --RCDWR 12
  • Effective Core 1440 (2 best cards set to 1444 core hit 1440 effective)
  • Memory 959
    *Vdd 900-918
198MH
  • Same strap as above ^
  • Effective Core 1405 (settings same 2 cards to 1409 gets 1405 effective)
  • Memory 930
    *VDD 875-900
183MH (samsung)
  • amdmemtweak --CL 20 --RC 36 --RP 11 --WR 14 --CWL 8 --FAW 12 --RAS 20 --REF 65535 --RFC 248 --RTP 5 --RRDL 6 --RRDS 3 --WTRL 9 --WTRS 4 --RCDRD 10 --RCDWR 8
  • Effective core 1300-1305 (settings range from 1304-1374)
  • mem 847 / SOC 850 OR if running that strap with RC 37 mem 875 no soc
  • vdd 837-868
Hello!
new to mining and trying to setting up the ERGO mining, but somehow i am getting very bad numbers?
i tried setting up at first setup but numbers arent even close??
i am doing something very wrong??
Gotta use TRM(TeamRedMiner) for the miner.
ok i will try that now are you having special setting for the pool??
Getting the N/A when i am choosing the TRM?
I dont have anything special, for the pool I use Wooly Pooly or Nano and just pick the closest server.
Might want to try making a new flight sheet from scratch, when updating existing flight sheets there are a couple things that can carry over and cause the miner to not initiate, in my experience its easier to make a new one.
I got it running but crashed very fast, saw the hashrate between 125-180 in the beginning, but now it wont be starting up again .
So I only notice i get a bump when socmhz goes up.
Am i changing the wrong setting?
When i see someone post 1100/900/870
I’ve set core mhz 1100, core voltage 900, mem mhz 870? Is that wrong?
I played around last night, got it 170mhz but after 4 hours crashed gpu dead, lowered clocks and now it ran 15 hours with 5 rejected @ 165 mhash
I think I’m missing a setting somewhere why must my mhz be so high?
Here’s where i was last night before crash
Here’s where I’m at currently, once i get the vega 64 dialed in I’d like to tweak the 56
Suggestions? Complete newb to hive os, maybe a command or setting I’m missing?
Thanks guys!
@bobber1988 I think its just OCs. Helps to know which cards died so you know which one to fix could just be one or two need a bit more power. Less core or more vdd is usually the fix for crashes. When switching to TRM and doubling the hashrate its likely they need more vvd to stay stable than on the previous miner.
64 settings look fine to me.
GPU 4 and 6 have too low mem for 1400 core so either drop that core closer to 1300 or bump up mem to 930.
If it doesn’t start mining after like a minute on ERG I typically just reboot the rig then it starts mining. Or if a reboot doesn’t start mining I plug in a monitor and watch, you can usually see that 1 card doesn’t initialize so the miner doesn’t start, and thats the card that needs more vdd or less core.
@Zr7s Yep you got it 1100/900/870 is core, vdd, mem.
So rejected are just stale share in ERG so that’s just a share submitted after that block was solved, typically its just latency between your miner and the pool. Using a pool server closer to you will reduce those rejected, I wouldn’t really worry about rejected unless it gets over 1%,
That 64 strap is likely the reason you need the high values, it is very safe. Try changing these 3 values:
RC 38
RCDRD 13
REF 65535
since those clocks are so high tighter straps might not work as well. Maybe that new strap on 1300 or 1400 core 960 mem.
Ok changed settings ising 1300/980/960 and it wouldn’t load the worker. Had a quick message flash up then this.
I removed flight sheet and oc, rebooted.
With it up and running applied overclock then started flight sheet and it wouldn’t load showing this message.
ugh either RC or RCDRD is too low, or REF is too high. I would roll back and try updating them one at a time see which one you card doesn’t like, RC is my guess.
I’ve been playing with core and mem mhz, makes no difference.
Rc and rcdrd I can increase individuality each by 1 and try each time but what about REF since it’s such a large number? Is there a fixed value to try decreasing?
