Undervolting try, it helped me, with 38 I did 45
I have a 2060 Super with Micro memory as well that is running in the 38 M/h range. After messing with this thing for about a hour within HiveOS, I think I see what is going on, but unsure how to resolve. I can core lock it by setting core to 1050 (really, it doesn’t seem to matter what you set the core at). I can get to 40 M/h if I set the memory to 1200. I have PL set to 184 (max on my card). With these settings I get 1050 MHz core and 7400 MHz on memory using 100W. If I increase memory to 1250 or anything above 1200, I get throttling on my card with a reason of PowerLimit. When this happens, my core drops to the 850-900 MHz range and the M/h drops. If I set memory back to 1200 (not going above 7400 MHz), the throttling goes away and I get 40 M/h again.
This would lead me to believe that this is most likely a power level setting within the BIOS once you cross over 7400 MHz memory clock. I have no idea how to go about fixing that within HiveOS though.
Hi
When you set as that stable, they will get rejected share or invalid share.
I run 72h or more with core 1100, mem 2100 (MSI 2060S) and get 43.5Mh/s (micron memory); Gigabyte is 44.1Mh and Nvidia is 44.8Mh that without any errors.
You can reset all if you want
Hi
You can try with this overclocking on HiveOS that not adjust on MSI Afterburner . After that waitting (30 seconds) and reboot your rig
Good luck!
Hi, I always have different shows, not stable balls, I can’t understand what the reason is, farmed both on 43 and her 44 and 45, always more than 2% of the rejected
me pasa exactamente lo mismo :C
Thanks man, works like a charm (Asus Dual OC), @42.07 though
Hola amigos creo que he dado con la solucion del problema lo primero es probar con mis overclocks tengo una kfa2 2060 super micron q no pasaba de 36 todo es debido al power limit como comentan por aqui es necesario ponerlo a 200 y activar el watchdog por seguridad con estos overclock el core se queda funcionando a 1050 y la memoria a 7787 no he podido conseguir mas sin bloqueo o perdida de imagen asi es estable y efeciente. Un saludo.
As i know thats all because your gpu card has micron chip. Most get 37,51hs. If samsung chip you can get 42-44 hs. For 2060Super 8GB.
All i can say we buy gpu same like play gatcha.
I have 4 gpu 2060S micron. 37,69, 37,69, 37,59 and 41.15 hs. Watt consumed under 100.
4 gpu 2060S Samsung, 44,28 , 44,28, 44,34 and 43,41 hs.
If there anyone found bios for micron to get more hashrate please share it. Thank you
Hi. I have 1 gpu 2060super with Micron chip. It has been running 44.4Mh/s since last 8 months.
Brand name: Nvidia - founder edition.
Core: 1050
Mem: 2100
P/L: 125
Power consumption: 100W.
The other one, Gigabyte 2060 super with samsung chip, it’s reach 43.6Mh/s only.
майниш на хайве?
версия ядра, драйвер какой?
p\l надо 0 тогда хавает максимум 100 ватт
Here,
Important is at the pool, average at the pool, for what you get payed
