I want sit the fan speed according to temp
hey guys i want use Hive OS but i want use the fan speed according to the Temperature
i eardy use windows with msi afterburner and i do it great
but i wonder if there is way to do the same here with Hive OS ??
i want set minmum fan speed to 40% if the temperature is 40 and it go faster to 100% if the temp 80%
imean when the Temperature go up the speed also follow it
i hope u undersatnd me guys and sory for my bad english :smile:
The afterburner Fan curve is a great. I want this feature also. Hope they add it to HiveOS. A simple solution to temperature issue.
I have written a script which does exactly this. Since I only have AMD cards, the script only works on AMD. You can set a fan curve, and then the script will turn the fans depending on the values in the fan curve.
Hi 1stnoblegas
Can you share this script for AMD cards? I would like run my AMD fans dynamically.
for nvidia: https://github.com/Steambot33/HiveOS-NVIDIA-GPU-autofan-2.0
Don’t you mind to share your script?
