How to Use Web UI to Overclock RTX cards
I thought I would share my fix to be able to use the web UI to overclock your RTX cards. I found the latests stable and beta releases are still trying to use the older method of setting overclocks per performance level (which does not work for rtx cards).
It’s a simple fix. This was done in the beta OS based on ubuntu 18.
nano /hive/sbin/nvidia-oc
Find the lines associated to setting the mem and core clocks.
GPUGraphicsClockOffset[$x]
GPUMemoryTransferRateOffset[$x]
Change them to this.
GPUGraphicsClockOffsetAllPerformanceLevels
GPUMemoryTransferRateOffsetAllPerformanceLevels
It should look like this after.
[[ ! -z $CLOCK ]] &&
        #nvidia-settings -a [gpu:$i]/GPUGraphicsClockOffsetAllPerformanceLevels=${CLOCK[$i]} | grep -v "^$"
        args+=" -a [gpu:$i]/GPUGraphicsClockOffsetAllPerformanceLevels=${CLOCK[$i]}"
[[ ! -z $MEM ]] &&
        #nvidia-settings -a [gpu:$i]/GPUMemoryTransferRateOffsetAllPerformanceLevels=${MEM[$i]} | grep -v "^$"
        args+=" -a [gpu:$i]/GPUMemoryTransferRateOffsetAllPerformanceLevels=${MEM[$i]}"
Stable version should look like this.
		[[ ! -z $CLOCK && "${PREV_CLOCK[$i]}" != "${CLOCK[$i]}" ]] &&
	fi
	if [[ "${PREV_MEM[$i]}" == "${MEM[$i]}" ]]; then
		echo "MEM CLOCK was already set to ${MEM[$i]}"
	else
		[[ ! -z $MEM ]]
Ctrl-X and Y to save
on your command “nano /hive/sbin/nvidia-oc”, is the nano in the command the miner used ie nanominer?
