Help with xinit.user.sh and saving Amdmemorytweak strap
Thanks! Worked.
It means run in the background…don’t wait for the command to complete.
I assume that you have to have the & in there? I did it without it and it didn’t work.
Yes. From the OpenBox Wiki ā€œMake sure that you end any commands with ā€œ&ā€ so that they are run in the background, or any programs after it will not run.ā€
http://openbox.org/wiki/Help:Autostart
I’m running 3 different straps just fine. Also, I meant to comment that the second red circle means add an extra line at the end.
It may help to configure a miner delay too.
the two circles is just to highlight that you need the & at the end and that you should put a line break in
Worked for me! Thanks! :+1:
Only modification I had to make was to add ā€œsleep 2mā€ before my amdmemtweak settings. Otherwise it would screw with the teamredminer tuning process.
here r some info may be helpful with hours testing for that strap-command-dont-work-guys :
step1:spark bell ;
2:type:nano /home/user/xinit.user.sh
3:get to the bottom with ur keyboard and rightclick+ctrl v your strap
4:ctrl+o,ctrl+x then y
5: back to the spark bell and type : sudo reboot
if it goes well ,your rig will reboot and mine with strap automaticly now ! :slight_smile:
Hey guys, I am really very new to mining but of course learning and reading every day. Maybe you can help me a little bit.
I have 2 MSI Vega 64 Air Boost models, that I have already flashed via hiveOS to Vega 56 Air Boosts. Where I’m struggling is the xinit.user straps thing. I just don’t know where I can edit these, so mentioned, straps.
So my Rig is running in another room, I am sitting at the computer, hiveOS 0.6-208@210818 running.
I open ā€œShell in A boxā€ but what do I have to do now for the straps and the xinit.user thing? Where I can open this file over hiveOS? Or am I completely wrong? :slight_smile:
hey guy ,just read every words in this post from top to the bottom,ull figure it out. it is necessary to learn by yourself if mining! it can be painful at first,but trust me ,ull be paid!
