it looks better yes, because you have reduced the temp and watts, while maintaining the MHs . which is a win win scenario.
I had crash. I ended up working with someone and changing a few tweaks around with TeamRedMiner.
So far we are 4hrs stable
you should have raised just the core voltage because i see you increased the core clock from 1170 to 1200 and that got you only 0.02mhs. now you have more heat from this. if you want you can test with 1170 core clock and 870 core voltage. if it does crash again raise it to 875 voltage.
Iād rather be a little over cautious and have stable clocks and voltages rather than teetering between unstable vs stable.
ok lower your core clock to 1170 ant test without lowering voltage.if it reduces the mhs to 31.08 and temp goes low. its a win.
