Help on payout - no longer mining
My mining rig died and I’m not planning on reviving it at this stage, and I read previously if there was no activity on the account for 30 days it would payout the balance.
It’s been way longer and I can’t seem to access anything that will allow me to get the funds out, the threshold also changed from 0.1 to 0.2 while I have balance.
How can I get the balance?
the auto payout after 30 days hasn’t been a thing for some time now. you need an active miner to change payout, min threshold is .0025 which you’re way over. if you have access to any gpu all you need to do is mine to that address for a share and then you can set the payout threshold in the pool payout settings
I have this problem myself
for etc or rvn?
