try this config setting these are the best
if you still not get 32mhs i send you another bios file
are u sure you not thermal throttling what your memory temp should be under 100c
friends, thanks for your time and help me, Help MSI rx580 8gb - #17 by webeast this help resolved my trouble, i flashing the bios with this bios and forced flashing and run with 31.5mhz, config
OC: 1150
VC:900
MemClock 2150.
thanks your help-
pd: always do backup for your memories original.
bye
great
i had the same problem …thank you very much now its working good (
