Has the payout threshold changed?
Same as any other eth traction on the mainnet. You’ll get a txid to follow and check once it sends.
I’ve used polygon on the wallet I’m using from ethermine to get payouts. I set my payout threshold above the .005 eth to .01eth to get payouts however when I try to get paid out. it says not enough balance to payout. Has anyone else run into this issue?
Did you already request once before the screenshot? If so that’s normal.
yeah I requested one before the screenshot. Does it have to wait till midnight to payout?
go through yet?
no, not yet. I just switched it back to my coinbase wallet to test if it’ll payout on polygon there. If not, i’ll just wait until it gets to .2 eth and get payouts less often.
after moving all my rigs to another wallet, I moved 1 worker to the wallet and then requested a payout. This worked and the payout happened now.
yes BS
would sux merge come and i cant mine to payout and hive just dont help and just stuck! would sux. I;m 51%
Get your payout now. Did you read the payout improvements at all?
this is the 3rd thread you’ve commented on but haven’t actually read the comments on the threads explaining the change and why its beneficial.
How do I find my ip address for my miner, it has no monitor and is running hiveos I’m pretty sure. I’m a stupid newb, and not happy about this payout change. I’m at a different location. I have to drive over there, hook up a monitor and request my ip?
Look at the bottom of your worker overview dashboard screen under remote ip. You don’t need to do anything locally or drive anywhere.
ooooo, thanks for the quick reply
