I have an issue with my EVGA RTX 3090 XC3. My 3090 is powerlimited in hiveOs for some reason. I wont get past 110mhs(+1000, everything above wont affect the card) at around 280w(I didin’t touch pl in hiveOs, I set it to stock).
I connected the card to windows to check if the memory junction temps are too high, but it isn’t and I had the same issue in windows; that it wont use more than 280/290w. What fixed the issue for me in Windows was increasing the pl to 104%, then it mined normal like all my other 3090 cards and I can set memory oc to +1500 in afterburner no issues at around 305w. But I don’t want to run the card in my main computer, so do you guys know a fix or a tweak I can do in hiveOs to fix my issue?
I have tried setting the pl in hiveOs to 366(max value for my card), but same result. It is stuck at 280w and “only” 110mhs
